creaking brakes.......
Old Jan 16, 2001 | 10:54 AM
acMAX's Avatar
anybody else have a problem with their brake pedal making a "creaking" noise when it is being pushed down or released?
Anybody know what in hell the sound could be? It doesn't happen every single time, but I assume if left alone it could grow steadily worse. Any ideas? opinions? comments? suggestios?
Old Jan 16, 2001 | 11:50 AM
UMD_MaxSE's Avatar
Got Bent?
Maybe the pedal assembly needs to be oiled? That would be the easiest thing to check first.
Old Jan 16, 2001 | 06:43 PM
psing23's Avatar
ye a lot of us have that problem... they feel like the pads are sticking to the rotors for a second... i think it might be the rust taht develops on the rotors, and i know under heavy braking and the brakes get hot it is imposible to stop and all it does is make noise... the stock brakes suck!! im gonna get a big brake kit soon
Old Jan 16, 2001 | 09:20 PM
tomz17's Avatar
I would guess rust too... It only happens on mine when they are cold (ie.. when I am pulling out of the garage), AND is MOST noticeable after I have driven in the rain/snow (ie. wet conditions), and then parked overnight..
It goes away, tho... so I'm not worried about it..
Personally, I don't find anything wrong with the stock brakes... Mine stick like glue!!!
-Tom
Old Jan 17, 2001 | 06:41 AM
UMD_MaxSE's Avatar
Got Bent?
I think it is ok if the brakes make some noise when you first start out. They are cold and have rust on them, so a slight grinding noise is acceptable. I thought the original poster was actually referring to the brake pedal itself. My brakes are fine so far....they stick fairly well.
Old Jan 17, 2001 | 07:16 AM
MOBOY's Avatar
Be careful!
I washed my car the other day to get the salt and grub off the car and I think the water from the sprayer froze on the rotors. I have never heard the sound that others claim....but that night I almost went through a stop light because there was sooo much ice on the rotors.
Old Jan 17, 2001 | 08:51 AM
blew226
Big Brake Kit & ABS
Does the kit interfere in any way with the functionality of the ABS in the car?
Brad
Old Jan 17, 2001 | 10:41 AM
acMAX's Avatar
internal noise:
the noise i am talking about is coming from the pedal.....not the rotors or the brakes. Only the pedal creaks when depressed or released.
Old Jan 17, 2001 | 01:47 PM
UMD_MaxSE's Avatar
Got Bent?
Re: internal noise:
So did you try some wd-40 on t yet?
kingw323
20
Oct 21, 2015 08:36 AM
thenewguyy
Sep 12, 2015 11:12 AM
tekmode
Oct 21, 2002 07:40 AM
Tanman
Jul 6, 2002 06:44 PM
