Which Tranny Fluid should I install on my 2003 6 speed.
Old Apr 9, 2003 | 05:23 AM
  #41
SR20DEN's Avatar
VQ Wizard
Re: Re: Re: Re: Re: Re: Re: Re: Re: I don't recommend Amsoil
Originally posted by Chinkzilla
Yes. If you do a full write up with pictures I will paypal you 50 dollars mark my word.
I should hopefully get my car back from the dealer today. They're doing TSBs and a warranty repair on my shift linkage.
I'll take a stab at it this weekend.
Old Apr 9, 2003 | 06:34 AM
  #42
Greek to the Max's Avatar
If you were to ask the dealer what gear oil to upgrade to, would they even have a option?
Old Apr 9, 2003 | 06:54 AM
  #43
Blu's Avatar
Blu
the tits
his paypal address is mstrength_109@hotmail.com
Old Apr 9, 2003 | 07:05 AM
  #44
SR20DEN's Avatar
VQ Wizard
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: I don't recommend Amsoil
And won't you be pissed when you discover I have access to that account. It's deep in theRED now.
Old Apr 9, 2003 | 07:15 AM
  #45
Blu's Avatar
Blu
the tits
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: I don't recommend Amsoil
cool now I have access to who admitted doing it...I hope buddy is nice to you in the slammer
Old Apr 9, 2003 | 08:17 AM
  #46
maxman00's Avatar
Ive been telling people this for years. Synthetic GL users be warned.
What is your opinion on a good dino oil?
Old Apr 9, 2003 | 08:22 AM
  #47
SR20DEN's Avatar
VQ Wizard
My 'opinion' is that you cant go wrong with a good Dino oil in a gearbox.
Perhaps Bill will step in and sumbit any GL data he has.
  #48
DAVEB's Avatar
Nissan has a TSB for an updated gear lube for 6-speed issues- It appears to be GL-4 75/85 dino. If someone wants to post it, just PM me your fax #.
Old Apr 9, 2003 | 08:24 AM
  #49
maximamaybe's Avatar
I did the AimSoil. It is still pretty notchy. I don't think anything will make this car shift like a German car.
Old Apr 9, 2003 | 08:26 AM
  #50
SR20DEN's Avatar
VQ Wizard
You have a PM
Old Apr 9, 2003 | 08:36 AM
  #51
CCS2k1Max's Avatar
A Honda 6-speed gearbox...
Darn, I was seriously considering the synthetic "upgrade", but you guys might have just lost iwannabmw some business...
Old Apr 9, 2003 | 09:07 AM
  #52
ABS's Avatar
ABS
I just learned about this one too. Apparently it is a "Nissan" brand lubricant (I wonder who actually manufactures it). At any rate, back when I had my clutch disc replaced (for the clutch howl TSB) and they refilled my tranny with the wrong fluid, I went crazy trying to find the correct GL-4 lube and then decided on Amsoil instead. Had the Nissan parts department known about the correct gear oil at the time, I would have used it, but they knew nothing.
The TSB you are referring to lists the particular part number for the gear oil. I believe the part number can be referenced here (admittedly it is not the entire TSB):
http://www.nissan-techinfo.com/nissa...3.asp?mscssid=
Old Apr 9, 2003 | 10:29 AM
  #53
SR20DEN's Avatar
VQ Wizard
The TSB can be found here in jpeg format.
56k friendly
Medium
Jumbo
Old Apr 9, 2003 | 10:40 AM
  #54
So let me get this right, if you have had warranty work done on the tranny, the recommend another oil grade?
Old Apr 9, 2003 | 10:48 AM
  #55
SR20DEN's Avatar
VQ Wizard
I don't think anyone said it was a different grade.
Old Apr 9, 2003 | 10:51 AM
  #56
So then what is it?
Old Apr 9, 2003 | 11:00 AM
  #57
SR20DEN's Avatar
VQ Wizard
So then what is it?
DAVEB needs to verify the OEM grade for sure but I think the message means:
"You lame **** Nissan techs better put the right freakin GL in the 6 speed and not some substandard crap you have on the shelf!"
Old Apr 9, 2003 | 11:11 AM
  #58
ABS's Avatar
ABS
Exactly! This is what happened to me. It is interesting to note that, I believe, the owners manual for the 2K2 6SPD calls for a 75-90 gear oil.
Old Apr 9, 2003 | 04:35 PM
  #59
iwannabmw's Avatar
56k friendly
Medium
Jumbo
So basically they switch to a lighter weight to improve shift feel. My question is how much will this affect the longevity of the transmission, especially in the warmer climates?
I know your stance on synthetic gear lubes, but as I said before, the life of your transmissions are also directly affected by the your driving style. Those can't be easy shifts to get those kind of trap speeds. I would be more interested in feedback about transmission/synchro life from people who drive normally. That would be more of an apples to apples comparison.
Old Apr 9, 2003 | 04:40 PM
  #60
iwannabmw's Avatar
If that's the case, so be it. I don't pressure people into using the products and I try to provide all the information I can so they can make a more informed decision on which route they want to go. I'm even nice to people who insist on using Redline
Seriously though, I get way more positive feedback from people than I hear complaints. Considering most people are likely to take the time to complain than to give positive feedback, that says something to me.
Old Apr 9, 2003 | 04:56 PM
  #61
CCS2k1Max's Avatar
might being the operative word here... I do agree that this is the first I personally hear negative feedback re: sythetics for the MTs. OTOH, there was some guy claiming his clutch pedal felt smoother after adding Redline. So much for feedback...
I also did notice that even the 2k1 5 speeds are included in the TSB, but not the 2ks. I wonder why???
Ray229Harris
Sep 16, 2015 08:16 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
mclasser
Aug 23, 2015 09:32 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
