Spring/strut install ???
Old Apr 17, 2003 | 07:09 AM
NikaL's Avatar
Every direction I read says to take strut mount off. My co-worker has done this on his Mustang and tells me that he put this car on jack stands, put another jack under the strut assembly, unscrewed the top bolt and slowly lowered a jack. He said he had to put a chain around springs for safety. He just reversed the process for installation. If this is the way, then rear strut install will be much easier too. Please let me know what you think, because my co-worker and I will try to install springs/struts this weekend. Also, sorry for bad English.
Nik
Old Apr 17, 2003 | 07:19 AM
Y2K2Driver's Avatar
Re: Spring/strut install ???
Nik
You could do that, but it really isn't a big deal to take out the entire strut and just use a spring compressor. If you are using a spring compressor on the front, then why not on the back? I think you're just asking for trouble the other way.
Old Apr 17, 2003 | 07:20 AM
WildmanAL's Avatar
Nik
Yeah that's what some of my friends did, but I rather just used a spring compressor so I can physically look at everything to make sure everything is on right.
Old Apr 17, 2003 | 07:54 AM
maxcosity's Avatar
don't use a spring compressor..
inside, flip the wheel around so the inside of the wheel is facing you.. now cover it with a thick blanket..
now point the top of the shock tower at yourself so you can see and the butt of the shock tower at your blanket over the wheel..
now unscrew the main bolt and when it gets off, the spring will uncompress quickly and shoot the bottom half of the shock tower into the blanket.. just make sure you hold the top in place or it will shoot towards you..
NOW.. to define "shoot" -- guys, you really don't understand how safe this is until you do it... the spring isn't all that compressed and it will only move the shock tower like 1 foot, so think about what kind of power is needed to move it one foot -- NOT MUCH...
so don't worry
but if you **** up or hurt yourself, I take no responsibility..
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
