AE Accelerator Pedal
Old Apr 24, 2003 | 07:04 AM
HSVMaxima's Avatar
Can someone post simple directions on how to install the AE accelerator assembly. I bought the assembly from Courtesy and wanted to make sure I put it on right. The How-To instructions are not completely clear. Thanks.
Old Apr 24, 2003 | 07:14 AM
255HP_03_SE's Avatar
Re: AE Accelerator Pedal
If you have a 2002 or 2003... this is the installation...
Remove the screw holding the accelerator in and it will detach from the side of the footwell.
Unclip the new AE accelerator pedal from the new pedal bar... you won't be using the new pedal bar. NOTE: Don't forget the little adaptor inside of the opening.
It is recommended that you disconnect the electrical and take the whole pedal bar assembly out but you don't have to... instead, unclip the old pedal off of the bar. Now, simply slide the new pedal (with the adaptor) onto the pedal bar. To clip the new pedal back on, you will need a small piece of black electrical tape... wrap that around once or twice (no more!) where the clip goes... clip the new pedal down.
Then, reattach the bar assembly with the screw... voila! You are done.
-R
Old Apr 24, 2003 | 07:21 AM
HSVMaxima's Avatar
Sorry, I have a 2000 which means I have to use the whole bar.
Old Apr 24, 2003 | 07:23 AM
If that is the case, it is even easier.
Unscrew the old bar assembly and disconnect the electrical connector.
Put the new bar assembly (and AE pedal) in and connect the electrical connector... then rescrew back on.
Voila!
Old Apr 24, 2003 | 08:02 AM
HSVMaxima's Avatar
Voila!
Thanks.
Old Apr 24, 2003 | 08:20 AM
Maxman2000's Avatar
Old Apr 24, 2003 | 09:00 AM
6spd_Hayes's Avatar
Thanks.
Got a way to post pics when you are done? If not, let me know and I will hook you up!
Old Apr 24, 2003 | 09:02 AM
I need somewhere to post pics... I have them now... can you clue me in?
Thanks!
Old Apr 24, 2003 | 09:17 AM
HSVMaxima's Avatar
Thanks!
I think he meant if I needed a digital camera to take pictures. We live close to each other.
Old Apr 24, 2003 | 09:20 AM
ahhhh... well, my question still stands. How does one post pics to the forums?
Old Apr 24, 2003 | 09:31 AM
When your AE pedals are in, don't forget to add the dead pedal... it is a great finishing look!
Old Apr 24, 2003 | 09:33 AM
jjs's Avatar
jjs
try this...
http://forums.maxima.org/showthread.php?threadid=182777
Old Apr 24, 2003 | 09:36 AM
6spd_Hayes's Avatar
If you have a place to link your picture from, it is easy to post pics. Most everyone here uses CarDomain. You will just have to upload your pics to them. The process to post images can be found here: Click!
Old Apr 24, 2003 | 09:43 AM
Yeah, well... I registered with CarDomain. Every time I go to my page to try to edit the page, it gives me an error. I've sent countless emails to CarDomain... no answer (big surprise).
-R
Old Apr 24, 2003 | 09:44 AM
jjs's Avatar
jjs
-R
Did you check my post or the Test Post forum for other sites?
Old Apr 24, 2003 | 10:43 AM
HSVMaxima's Avatar
Actually, I already have the AE brake and clutch pedal as well as wild ******* 350Z dead pedal replica. Shift **** too!
Old Apr 24, 2003 | 10:53 AM
6spd_Hayes's Avatar
Think youwill ever do the AE body kit? In the color of your car would look very good. It would definetly be an original.
BTW, did you check out the Yellow Max in the SE Forum?
Old Apr 24, 2003 | 11:47 AM
HSVMaxima's Avatar
Yes, I saw it. I just don't know that I want to spend that kind of money on the body kit. The guy at Nissan tried to get me to buy it at employee price ~ $800 if I remember correctly.
Old Apr 24, 2003 | 11:49 AM
What SE forum? Where?
Old Apr 24, 2003 | 11:53 AM
jjs's Avatar
jjs
http://forums.maxima.org/showthread.php?threadid=209068
Old Apr 24, 2003 | 11:55 AM
scmaxima2k's Avatar
Hey guys, I just did my AE pedals last weekend on my 2k auto. When i bought them i just bought the accelerator pedal itself and not the entire assembly. To put it on i had to wrap the end of the accelerator assembly bar(where there is a little bend at the very botton of the bar) with electrical tape to thicken it up and then to keep the top of the pedal secure, i broke off the little clip from the original pedal and did a little modification to make it fit onto the AE pedal and make it fit. I probably didnt explain this very well but i tried .....Anyways heres a pic of my pedals:
-Steve
Old Apr 24, 2003 | 12:06 PM
6spd_Hayes's Avatar
-Steve
Steve, is that the 350Z Dead Pedal or the Wild ***** Dead Pedal? Looks good!
Old Apr 24, 2003 | 02:13 PM
scmaxima2k's Avatar
Thats the 350Z Dead Pedal. Thanks!
-Steve
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
leatherneck
Sep 30, 2015 09:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
