sunroof woes
Old Apr 26, 2003 | 01:11 PM
GLE2000's Avatar
sunroof woes
Has anyone had any problems with their power sunroofs? when I try to open it, it moves about 3 inches then stops. I then have to press the button again and it will move another 3 inches, so on and so forth until it is open. Same for when it closes. I think it is the switch, but I have not had time to pull it and test it. Just wondering if im alone
Old Apr 26, 2003 | 01:16 PM
McDisneySoft's Avatar
No movement issues, but I do get an annoying rattle/squeaking sound from the roof right next to the sunroof.
Old Apr 27, 2003 | 10:35 AM
griffy2k2max's Avatar
Re: sunroof woes
Have You recently disconnected the battery for any reason?
If so with the sunroof closed push the switch on the closed side and hold it for 5 seconds or until you hear or feel a click. that will reset the sunroof sequence, it should work after that.
If you have not done anything regarding the battery then it sounds like the switch is shorting out. Hope that helps.
Old Apr 27, 2003 | 10:37 AM
Maxman2000's Avatar
My 2k don't do it.
Old May 10, 2003 | 11:47 AM
GLE2000's Avatar
Re: sunroof woes
I fixed it! It had to either be a problem with the switch or the relay. The switch checked out fine, so I pulled the relay and tested it for continuity. It was fine so I put it back in. After putting it back, the sunroof started to work fine again. My guess is that the circut breaker in the sunroof motor needed to be reset. Now Im cruzin in style again Thanks to anyone who posted suggestions! I have a spare runroof switch if anyone is in need of one
Old Oct 30, 2003 | 08:29 AM
rugrat01's Avatar
just as GLE2000 posted...i did the same thing to my 2000 SE...pulled the relay...and plugged it back in. works perfect!
thanks!!! and thanks for saving me a $300 trip to the stealer!
Old Oct 30, 2003 | 09:10 AM
Prodigy's Avatar
Mine did the same thing over the summer for about 3 hours, then it just started working normal again...Weird
Old Nov 17, 2003 | 11:50 AM
kgibso01's Avatar
Thanks for all the replies, just bought my maxima and it fixed it straight away. Unhook the battery, hook it back up easy as that.
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
Vequity
Sep 10, 2015 05:26 AM
