reset ECU with K&N filter
Old Apr 28, 2003 | 09:36 AM
BiggD23
Is it really necessary to reset the ECU when installing a K&N panel filter on a 2k3? If so, how do you do it? I'm going to be putting one in my car tonight. Thanks for any help.
Old Apr 28, 2003 | 09:40 AM
mzmtg's Avatar
Minister of Silly Walks
No.
The ECU is constantly learning.
Old Apr 28, 2003 | 09:55 AM
MaXBoost03_SE's Avatar
No you don't
I installed one of these recently, and it doesnt require you to reset your ECU.
Old Apr 28, 2003 | 09:59 AM
CVicVogel's Avatar
I'm glad to hear you are trying out the K&N.
However, it seems that the postings possibly seem to indicate that you have a greater chance of fouling the MFM (mass flow meter) with a oil-impregnated air filter.
Is this true? Will a K&N foul the MFM faster? Is it covered under the warranty?
thanks
Vic
Old Apr 28, 2003 | 10:03 AM
jjs's Avatar
jjs
I have had one of the K&N drop in's for over 20K miles and already serviced it once. Not a single problem and no ECU reset.
The single biggest issue with 'oiled filters' is overoiling them. I cleaned the filter element with the 'recharge kit' and then put just enough oil back on it to lightly color the pleats (basically the insstructions on the bottle). The thing I like to do is use a clean towel and lay the filter on the towel for a few hours to 'leach' off any excess oil, then wipe the frame of the filter to remove any other excess.
Old Apr 28, 2003 | 11:28 AM
BiggD23
OK, I was hoping I wouldn't really have to reset it. The K&N website says that you have to do it so the ECU adjusts to the higher airflow. Thanks for the input guys.
Old Apr 28, 2003 | 03:19 PM
2k2max's Avatar
I recently recharged my cone filter and did the same as you described. Despite what K&N says about good performace with their dirty filter, a clean recharged filter is AMAZING.
About the ECU, I don't think you really have to reset it. If you do, it wouldn't hurt anything.
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
Justin Kroll
Oct 1, 2015 07:03 PM
Redfox
Sep 28, 2015 10:41 AM
