Drilled rotor behavior question
Old Jun 19, 2003 | 01:31 PM
ajahearn's Avatar
I just installed the Stillen drilled rotors all around. I used Axxis Metal Master pads on the front and Raybestos pads on the rear. I followed the break in procedure as defined by Stillen.
I now have a few 100 miles on them and I noticed that during braking I get a kind of rumbling noice and feeling through the brake pedal. It is not the kind of rumbling you get with warped rotors. I've never driven a car with drilled rotors and I was wondering if this is normal. Any answers?
Thanks in advance.
Old Jun 19, 2003 | 02:44 PM
vizslak7's Avatar
I have them on my 2K1 all around, metal master pads on the front and stock pads on the rear and I have not noticed anything but smooth braking from any speed. I have had them on for about 20,000 miles.
Old Jun 19, 2003 | 03:34 PM
Maximam's Avatar
Mine are noisy with highspeed stops. Close to what you are describing.
Old Jun 19, 2003 | 03:52 PM
ajahearn's Avatar
I've been accused of having a heavy foot but I don't consider myself doing highspeed stops. The rotors look fine to the naked eye so I'm going to assume they are okay.
Old Jun 19, 2003 | 09:04 PM
maxgsxr1
are crossdrilled rotors worth buying?and highway pulsation?
Old Jun 19, 2003 | 11:17 PM
thomasd cook's Avatar
I've got x-drilled and slotted rotors, mine also makes a lite rumbling sound when coming to a stop. Did you install these yourself? I also hear a light clicking sound coming from the rear of both wheels. I installed my rotors myself and on the rear I didn't remove the emergency brake cable from rotor when installing. Would that have something to do with the clicking? If no one knows what this problem is do you think I could bring it back to the dealership for them to cover it under warranty? I wouldn't think they would cover it.
Old Jun 20, 2003 | 04:33 AM
dougb's Avatar
I had a groaining noise that was obnoxious. Took it to the dealer and they turned the rotors and suggested putting a set of softer pads on. The axxis pads were really chewed up. So I went back to Nissan's pads since I was there and everything has been fine for the last 10,000 miles.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
05RLS2
Sep 27, 2015 09:24 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
