Let's play the diagnose my car game ^_^
Old Jun 21, 2003 | 04:17 PM
Critical's Avatar
Ok, I have a 2000 with about 90,000 miles on it. I've always had my scheduled services done, and had oil changes every 3000 miles excep 2 goof ups where I went to 4000. Approxmiately 2 months ago I was doing some city driving an when I stopped at a red light my car idled rough for a second, then lost rpm, then died completely. The following morning it did the same thing again, then again, and again, ... and then it did it again while i was making a right hand turn. Took it to the Nissan service shop here and they said I had a bad MAF sensor, they replaced it, the problem went away. Fast forward to a week ago, I started having the problem again. But before I went to take it into the shop again I got my oil changed, after I got my oil changed the problem went away and hasn't come back ... but obviously the oil change was only a temporary fix. I don't want to take it into the service dept. again, have them do some 400 dollar repair, and still get the same problem again ... I'm befuddled
Old Jun 21, 2003 | 09:41 PM
swiftytoenails's Avatar
I'm no mechanic, but it could be the fuel pump. I've had a similar problem with another of my cars and a new fuel pump fixed it right up. Hope this helps, cuz I have a 2000 GLE and I'd hate to see one go up.
Old Jun 22, 2003 | 02:33 AM
andrew3616's Avatar
Could be your Throttle body, maybe you need to clean it out
Old Jun 22, 2003 | 01:13 PM
ajahearn's Avatar
Fuel filter is another possibility. Is SES light ever on? You should ask someone to see if its throwing a code.
Old Jun 22, 2003 | 01:44 PM
BlueStreak's Avatar
that sounds simmalar to the problem that i had except that it threw a code and the SES light came on. end result was a camshaft balancing sensor. btw i have a 00 with 99000 miles.
Old Jun 24, 2003 | 05:45 PM
bahkhok's Avatar
Has the problem only happened when it is hot outside?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
BobMax
Aug 19, 2015 04:39 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
altome15
Aug 10, 2015 07:05 PM
