Installed Injen CAI, now freaky idle.....
Old Jun 23, 2003 | 10:17 AM
ukeyman's Avatar
I've had the intake on for about 60 miles and the idle has been odd since I installed it. Basically, no matter if I just goose the gas or am slowing from speed, the tach will stay at 1200-1300 for about 3 or 4 seconds then continue down to regular idle. Basically, I'm driving along and let off the gas, the tach drops normally until 1200rpm, sits there for a few seconds then continues on. Did I do something wrong? This is an auto and I've already checked to make sure the cable is clear, it is. I also disconnected the negative battery hookup when I was installing the intake. Any suggestions?
Thanks,
Mike
Old Jun 23, 2003 | 10:39 AM
SupaFly's Avatar
Re: Installed Injen CAI, now freaky idle.....
I would leave the battery disconnected for at least 24hrs. Let the ecu entirely reset itself.
Old Jun 23, 2003 | 10:43 AM
yongjun's Avatar
sounds like you have a blown maf
Old Jun 23, 2003 | 10:45 AM
SupaFly's Avatar
Are you able to rev above 2000rpms?
Old Jun 23, 2003 | 10:47 AM
BiggD23
Re: Re: Installed Injen CAI, now freaky idle.....
Hasn't it been determined that on the 2k2-2k3s disconnecting the battery doesn't work to reset the ECU?
Old Jun 23, 2003 | 11:05 AM
SupaFly's Avatar
Re: Re: Re: Installed Injen CAI, now freaky idle.....
It worked on mine when i installed my injen (i now have firm fabrications intake). I got an SES light and i left it disconnected for 1.5 days and it went away...no problems.
Old Jun 23, 2003 | 12:09 PM
ukeyman's Avatar
I can rev normally and drive normally - the improvement is noticable. It's just when it's coming down that I experience the problem. Makes driving in parking lots a little tricky.
Old Jun 23, 2003 | 02:05 PM
MannyNJ2k2max's Avatar
Might have a leak man- check hoses for pin holes-
Old Jun 23, 2003 | 03:46 PM
92 SE-R 02 SE
Re: Re: Re: Re: Installed Injen CAI, now freaky idle.....
Check all the couplers, make sure they are tight and no air is getting out.
Old Jun 23, 2003 | 03:49 PM
PCGuRu2K's Avatar
Sound like either an air leak, the ecu needs to relean the air fuel curve, or the MAF is on it's way out.. For me it was the MAF back then when I had the Injen.
Old Jun 23, 2003 | 07:57 PM
ukeyman's Avatar
Thanks for the suggestions, looks like I'll be going back through my install to check for leaks - hope it's that and not the MAF. I'll post once I find out what it is. Thanks again.
Old Jun 23, 2003 | 09:32 PM
ukeyman's Avatar
One last thing, I noticed that the plastic apron along the bottom of the bumper looks like it blocks airflow. Anyone ever take these black pieces off to free up more room for air to get to the intake? Did it make a difference?
Old Jun 23, 2003 | 10:25 PM
2k2kev's Avatar
It's chrome alright...
I left the plastic on to ward off water splashing up on the filter. If you remove it, give it a feel after driving in the rain and let us know how wet it is... I'd like to know.
thanks,
Old Jun 23, 2003 | 10:50 PM
foodmanry's Avatar
Da Roller Coaster!
thanks,
I've had my enginer cover down there off for about 10K miles. Been through some rain and no problems at all, even some puddles as well. It should be ok, just watch out for deep puddles and the air filter is going to get dirty quicker.
I didn't feel much of a difference, but it made about a tenth or two-tenth second change on my quarter mile.
Old Jun 26, 2003 | 01:32 PM
ukeyman's Avatar
It worked! Runs like a top and idle is back to normal. Thanks for all of the suggestions I wouldn't have known what to look for. SupaFly, next time you'r ein the Baltimore area, I'll buy the beers.
Old Jun 26, 2003 | 03:29 PM
SupaFly's Avatar
Glad to hear it..Baltimore, eh?
Old Jun 26, 2003 | 06:48 PM
ukeyman's Avatar
Yup, just outside. Be up in NYC middle of next month though. Haven't been in years, looking forward to it.
Old Jun 26, 2003 | 09:56 PM
clipse's Avatar
Since we are on the subject of intakes,Would it be wise to leave the battery disconnected for 24HRS prior the installation of any aftermarket intake???
Old Jun 27, 2003 | 04:56 AM
SupaFly's Avatar
I would assume that if you disconnect the battery the day before and the next day install the intake, you wouldn't have to wait after installing the intake to start the car up and take it out. The ecu will already be reset.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
A32goldylocks
Sep 16, 2015 01:33 PM
Johnny9595
Sep 3, 2015 05:18 AM
