Is my auto tranny dying?
Old Jun 24, 2003 | 12:26 PM
schuss's Avatar
so, it's been getting steadily worse for the past two weeks or so.
i start my car, and put it into drive to head to work or whatever, and it's only half-engaged into first until half a block later, then it finally kicks in. at first, it was just a second or two, but it's steadily growing to several seconds.
also, it occasionally slips when i get started again on a green light, or after a stop sign. so far it just seems like first gear, as once i'm on the freeway or moving in traffic it shifts normally, as far as i can tell.
it also doesn't seem to happen at the end of the day, when it's (a assume) more warmed up. but it's not like it's been really cold lately or anything.
i've been trying to let it idle a bit before i take off in the morning, but i know i've been really bad about that in the past.
so, is it time to start saving up for a new one?
my car has a little over 69k on it. i'm driving out of town this weekend, will put about 1800 miles on it. i'm pondering getting the tranny flushed before i leave (i think it's only about 60-70 bucks) - think that would help? or is it a waste of money? the last one was at 52645.
help!
Old Jun 24, 2003 | 01:29 PM
PCGuRu2K's Avatar
Time for a 5spd conversion
Old Jun 24, 2003 | 03:28 PM
Maximam's Avatar
What was your total cost to convert, I am leaning toward your direction.
Old Jun 24, 2003 | 03:35 PM
Jeff92se's Avatar
I'm needing a caw
Hmmmm, I'm not an expert by a long shot but.. solenoid out? Sounds like the tranny is not developing enough line pressure to get it to stay in gear(or whatever?) I would maybe pull the stick and see if the fluid looks burnt or brown(vs clearish red color)
Old Jun 24, 2003 | 03:37 PM
MadXtreme01's Avatar
I had this problem too, except it was while shifting from 2nd to third or even 3rd to fourth. i found myself gunning it to pass someone on the road and it didnt kick in for another 5-8 seconds when there wasnt enough room to pass anymore. Eventually the tranny blew, luckily the car was still under warranty so it was replaced but it took 2 weeks for the job to be done, and i still dont think it responds the way it should. i had 2 people in the car other than me and i only beat a stock 00 4cyl 5spd accord coupe by a car length with od off.
Old Jun 24, 2003 | 07:00 PM
PCGuRu2K's Avatar
Well the conversion part ain't gonna be that much. With parts and everything it'll come out to like $2200-$2500 with act clutch..
But then you can always add a flywheel,quaife,urethane mounts and it'll get costly But it's definitely work it
Old Jun 24, 2003 | 10:04 PM
schuss's Avatar
it doesn't look brown, but it smells burnt, a little. i'm going to have it drained and flushed tomorrow at my FNND. (it's okay, i have a friend that works there, he'll be the only one touching my car). i'm hoping that will help.
it seems to also not want to drop in and out of overdrive, especially into overdrive when i let off the gas at highway speeds (where it would usually upshift into overdrive).
thanx, jeff. my dad said the same thing about the solenoid, or that maybe there's a belt adjustment i might need.
i'll let you guyz know what i find out...
Old Jun 24, 2003 | 10:09 PM
Jeff92se's Avatar
I'm needing a caw
I think there's also a tranny ecu diagnostic also. Browse the stickies or search for the info. Good luck. I hope your tranny ain't going **** up.
Old Jun 24, 2003 | 10:13 PM
schuss's Avatar
yeah, me too!
i really wanted to keep this car for awhile, but if it's gonna start to fall apart... it's gone.
Old Jun 24, 2003 | 10:14 PM
Max2000SE's Avatar
Had the same problem in my 2000,,,Just took it last week and they updated the ECU and replaced a solenoid...Working absolutely fine now...Prob is the same thing..good luck
Old Jun 24, 2003 | 10:18 PM
lcf's Avatar
lcf
Unfortunate that you're over 60k! There's a TSB for solenoids.
Jeff92se's Avatar
I'm needing a caw
Decent basic reading. From 3-gen chiltons
http://www.cybrrpartspro.com/Chilton...61CH07_12.HTML
Old Jun 24, 2003 | 10:24 PM
lcf's Avatar
lcf
SOLENOID TSB
Old Jun 24, 2003 | 10:42 PM
schuss's Avatar
SOLENOID TSB
thanx for the link - i read it, sounds like my problem. too bad my warranty expired 10,000 miles ago...
jeff - i read the chilton's link - thanx! - but i'm gonna have to read it again in the morning when i'm awake if i want to understand it...
fx4five
Oct 18, 2015 06:57 PM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
maxima297
Sep 30, 2015 03:32 PM
