Beware the Frankencar intake with no support bracket.
Old Jun 26, 2003 | 10:56 AM
maximamaybe's Avatar
Long Story below:
I have had my Frankencar intake installed for around 10K miles. I used one of the stock bolts that were from my stock intake. Well, it kept coming lose and one time I tried tightening it, it snapped. Therefore I drilled the bolt out, but I decided to leave the bolt off. BIG MISTAKE. Last night I pull into the garage and notice that my car is smoking from under the hood. I started fraking out. Turns out that the Frankencar rubbed a small hole in the AC line. For your own benifit, I recommend to secure your Frankencar or suffer the consequences.
Here are pics.
Old Jun 26, 2003 | 11:25 AM
Y2KSESteve's Avatar
Thats not good. I'm glad I removed mine before anything like that happened.
Old Jun 26, 2003 | 11:40 AM
MaxSE03's Avatar
Hmmmmmm...I have 14k on mine, better go check.
Looks good! My Monsterflow doesn't touch the AC line. At least you found it before it got worse.
Old Jun 26, 2003 | 11:59 AM
I also noticed that the filter is rubbing quite a bit on the wire loom that sits underneath the filter and in front of the strut tower.
Old Jun 26, 2003 | 12:03 PM
Menasor's Avatar
Re: Beware the Frankencar intake with no support bracket.
Originally posted by maximamaybe
Long Story below:
Here are pics.
That is the same line that I busted, but for a diffrent reason. You are looking at 65-$100 to replace that line. The dealer charged $103 but I got it online for 65 plus shipping. The smoke you saw was refrigerant coming out, but you know that already. After I installed the new line I put wire loom over it so what happend to me won't happend again. I hope. As for the frankencar mount. I ordered a midpipe and was dissapointed that I wasn't able to use the stillen mounting harware. So I had to ghetto rig one. After reading this I am glad that I did. Good luck on fixing that line.
Old Jun 26, 2003 | 12:09 PM
I have a connection at an Infinity dealer. Thanks t56gen3 for the hookup. It will be around 57 for the line and a couple of bucks for the O rings. The guy is also going to let me use the devise to drain and refil the AC. This really sucks. Now I really wish I would have bought the Injen.
Old Jun 26, 2003 | 01:24 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I knew something like that was going to happen.
That's why I still have mine in the box.
Since the OEM supported the MAF, I'd make sure you do too.
Old Jun 26, 2003 | 01:55 PM
chinaonnitrous1's Avatar
41k with no holes..although i did wrap up the wire loom in electrical tape.
Old Jun 26, 2003 | 02:20 PM
MaximaMan77's Avatar
FIRM FAB.
Old Jun 26, 2003 | 02:21 PM
IceY2K1's Avatar
Originally posted by maximaman777
FIRM FAB.
Que?
Old Jun 26, 2003 | 02:49 PM
FIRM FAB.
I got mine for much less from an .orger and have my Stillen attached to it with the Frank bracket holding it in place.
Old Jun 26, 2003 | 02:56 PM
IceY2K1's Avatar
FIRM FAB.
Ok...I see. Hopefully, yours doesn't have the blow-off flange though.
Old Jun 26, 2003 | 02:57 PM
mdeal's Avatar
Similiar experience here with a PR intake expect it was not my AC line but one of those brake lines shown in the picture. Lost all brake fluid and eventually the brakes. Had to have it towed to the dealer and have that line replaced (it went to the front left brake).
Old Jun 26, 2003 | 03:01 PM
IceY2K1's Avatar
Oh thanks....now that's going to sit in the box and collect dust in my garage.
Old Jun 26, 2003 | 03:13 PM
MaxSE03's Avatar
I would say that is a little different story. AC vs Brakes. I know which one i could do without.
Old Jun 26, 2003 | 03:15 PM
Brakes. I live in Texas. LOL
Old Jun 26, 2003 | 03:42 PM
MiniRX7's Avatar
I have the same exact problem.. For now i wrapped the line with electric tape.
The best solution is use washers to lift the bracket a bit higher...
ED
Old Jun 26, 2003 | 04:13 PM
IceY2K1's Avatar
I live in the AZ desert. Texas aint sheit. LOL
Old Jun 26, 2003 | 06:13 PM
We have humidity. Dry desert heat aint sh*t.
Old Jun 26, 2003 | 06:20 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
pic doesnt work
Old Jun 26, 2003 | 09:36 PM
IceY2K1's Avatar
125F+ doesn't matter if it's wet or dry, still unbearable. I've been to El Paso, it aint sheit.
I thought humidity is better for performance?
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
