Dealer and the tsb's
Old Jun 28, 2003 | 12:38 PM
JimboMax's Avatar
Went for my 15,000 maintenance the other day. While there I showed the mechanic my printed out copy of tsb's for my 2k2 6 speed. I told him I've been having problems with the howling noise and the hesitation in third gear. About an hour later he called me and told me they needed to order (going off my paper) disc assy clutch, cover assy clutch, and bearing clutch. Also, they ordered a new Maf that needed a new ECU update. For anyone who had these tsb's done, are these the correct parts?
Old Jun 28, 2003 | 01:15 PM
mille_3's Avatar
Re: Dealer and the tsb's
Don't know about the clutch parts, but I just had my ECU updated last Monday and I didn't need a new MAF. I guess some do others don't according to the TSB. But even if they order all those parts you aren't paying for them so what's the difference. it would be worse if you stood there with the TSB in hand and they would do nothing for you.
Old Jun 28, 2003 | 01:26 PM
perrymaxima's Avatar
were did you find the TSBs if there is a link plese post it for me. Thanks
Old Jun 28, 2003 | 02:01 PM
nismaniac's Avatar
Here's the link for the TSB's: Clicky
Old Jun 29, 2003 | 12:59 PM
redstradic's Avatar
whats considered as the TSB for hesitation on an auto? i am guessing the transmission slipping?
Old Jun 29, 2003 | 01:47 PM
nismaniac's Avatar
The TSB that I believe you are refering to is for Automatic 02-03 maximas and altimas that use the drive by wire (electronic throttle) system. It deals with the MAF sensor and/or reprogramming the ECU with an updated drive by wire program. Check out the link above for all TSB's...
Old Jun 29, 2003 | 02:29 PM
mille_3's Avatar
It applies to the 6sp as well. just had mine done
Old Jun 29, 2003 | 04:09 PM
redstradic's Avatar
what about a 2k auto, are they any TSB that are just blantant for a 2K that I should go check. Just bought one about a month ago and i have 33K on it and I want to make sure I get all the warranty work done before the 3 year/36k warranty. thanks
Old Jun 29, 2003 | 05:52 PM
nismaniac's Avatar
The link in my earlier post contains almost all TSB's for the 5th gen. That's defintely a link everyone should have in their favorites!...
D Mason
Jun 21, 2016 04:43 AM
mpbclutch33
Dec 26, 2015 11:11 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
AboveDaCloudz
Oct 8, 2015 11:25 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
