Coolant level too high.. .what do I do?
Old Jul 2, 2003 | 08:06 AM
sardarg89's Avatar
As usual, I put too much trust in my dealership. Went to get my oil change done there about 3 weeks ago. Their policy w/ an oil chance is to check all the fluid levels and to grease the door hinges.
Anyways, two days after I got the car back, the hinges were bone dry (what can I do for this? Lithium grease?). I checked the fluid levels, and the coolant reservoir was way below the "full" hash mark. Stupid as I am, I bought new coolant and filled the reservoir almost to the top before realizing that it's not supposed to be filled that much.
Am I going to cause any harm? If I have to remove the coolant, how do I do this (without having to siphon it out.. yuck)? Maybe I can get a cat to drink it... hehehe
Old Jul 2, 2003 | 08:17 AM
Maximax2's Avatar
Re: Coolant level too high.. .what do I do?
Why "yuck" for siphoning? Get some plastic flexible tubing about 4 feet long if you're concerned about "drinking" it, then siphon it out. The tubing should cost about a buck at Home Depot - easy.
Old Jul 2, 2003 | 08:26 AM
sardarg89's Avatar
well I was wondering if I really need to remove it... anyone???
Old Jul 2, 2003 | 09:07 AM
bigdo26's Avatar
when i bought my car (new) the coolant was overfilled. hasnt been a problem yet
Old Jul 2, 2003 | 09:10 AM
Richard Scott's Avatar
Use a turkey baster and get the coolant level sown to where it is susposed to be.
Old Jul 2, 2003 | 09:36 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
you could just remove the 10mm bolt and pick up the plastic tank and pour out the excess.
Old Jul 2, 2003 | 11:43 AM
Maksim2000's Avatar
Or you can just unhook the radiator "overflow" hose from the radiator filler neck (one sprng clip) and use it to drain out the extra fluid...
Old Jul 2, 2003 | 03:17 PM
02'maxed-out's Avatar
Did you also add distilled water to it???
Old Jul 2, 2003 | 06:33 PM
saxdogg's Avatar
yeah, two words: TURKEY BASTER.
All of my fluids came overfilled from the factory.
ARFF
Old Jul 3, 2003 | 03:50 PM
sardarg89's Avatar
thanks guys.
No, I didn't add water to it.
Yes, I am stupid.
Old Jul 3, 2003 | 10:22 PM
ZAJOBA's Avatar
hope you knew what antifreeze to use.
if you mix wrong types of antifreeze you can get GEL in your system! (mixed antifreeze becomes gel)
Old Jul 4, 2003 | 01:59 AM
TZapper's Avatar
Redline WaterWetter?
Old Jul 4, 2003 | 01:45 PM
swampman's Avatar
Let the coolant overflow handle the excess coolant and do nothing.
Old Jul 4, 2003 | 08:41 PM
sardarg89's Avatar
Thanks, guys.
Old Jul 5, 2003 | 06:48 AM
Street Reeper's Avatar
Handsome
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
Need help
23
Oct 2, 2015 08:56 AM
sliptap
Sep 30, 2015 05:57 AM
