Newbie but not stupid ?'s........
First of all what's up everyone, first post so sorry if you've seen these questions a million times, couldn't get the search to find anything.
Just bought an '00 SE auto (wife made me get the Auto)
53000 miles
Two things are buggin me:
1. On fairly hard acceleration, at approx. 3500-4000 rpms the power dips and the car lags for a second. Doesn't feel like the tranny hesitating like I've read on here that has a TSB out, because the car doesn't shift til about 4500 at this acceleration rate. Any ideas?
2. Live in AZ and after the commute home when everything is good and hot I have a buzzing sound for about 5 minutes at the back end of the car the sounds like the fuel pump is still going. Literally for about 5 minutes then it slowly tapers off and pulses for a while. Thought it could have been the motor mounts problem but it is coming from the back of the car.
All thought's are appreciated, I plan on doing a full tune-up regardless, plugs and all. But am interested if anyone else has had these problems.
Thanks fellas,
Love the car, first car I've ever bought, typically a truck guy but needed a pavement pounder for my commute.
Late.
53000 miles
Thanks fellas,
Late.
Re: Newbie but not stupid ?'s........
** Get a divorce. j/k
53000 miles
Thanks fellas,
Late.
Late.
I also have 53,000 miles on mine and have to do a tune-up. My advise for you is to change the plugs first. I've heard on here that you can feel the difference with dirty plugs. Also, change the tranny fluid and do a coolant flush. About that sound, I'm not sure. It could be detonation that you are hearing, are you using premium fuel? Once again I'm not sure just trying to help you out
Update:Kicks in ~6500 RPM then changes gear. Sorry that's not it.
Good luck & welcome.
53000 miles
Thanks fellas,
Late.
53000 miles
Thanks fellas,
Late.
Re: Re: Newbie but not stupid ?'s........
Originally posted by Lumbee1
The 00's and 01's suffered from bad coils. There is a TSB out for it. Symptoms are decreased power from 2000 to 3500 rpm's along with sporatic pinging from the engine. A $600 job if you are out of warranty.
Check your tranny and coil TSB's as listed in the FAQ'S or stickies in this forums.
Crawl under the back of the car while it's "buzzing" and look around/listen. THere are some emissions components back there as well, right under the rear bumper.
JP
JP
I'm not sure about your hesitation issue but the buzzing sound that you are hearing is indeed from the fuel pump. I have a 2001 SE and it sometimes exhibits the buzzing noise after shut-down. It's quite normal seeing as that the fuel system is under a lot of pressure and in your region of the country it gets really hot! My suggestion is to loosen the cap the next time you hear it, SLOWLY though. Re-install the cap and your noise will go away. My 1994.5 Sentra LE does it also on occasion. Nissan replaced the fuel pump under warranty, when the car still had the Security Plus Gold Warranty even though my tech said the noise was "Normal." Good Luck, I hope this helps.
53000 miles
Thanks fellas,
Late.
53000 miles
Thanks fellas,
Late.
CorollaULEV
30
Aug 9, 2021 08:11 PM
pears
Sep 18, 2015 05:25 AM
A32goldylocks
Sep 16, 2015 01:33 PM
carlosvq30
Aug 17, 2015 11:32 AM
Be sure to check the regional forum for AZ meets.
