Dealer thinks I need a new Pre-Cat (front pipe)
Old Jul 24, 2003 | 06:33 AM
BennysMAXIMA's Avatar
Yesterday I took my Max in to get the ECU re-programmed. I was getting a P0420 error. Upon bringing it there I had the dealer tells me I had the newest Software version in my ECU. Anyway next he proceeds to tell me I need a new pre-cat (front pipe). After more though question and concerns (30 minutes of me asking questions) finally a mechanic comes in and tells him there is a newer Software Rev. They reset my SES light but i'm pretty sure it will come back on.
Anyone ever have this problem before? Did the new Pre-Cat fix it (609.38 for part & 260.00 for labor OUCH!!). Wonder why they won't put in a new cat and see if that fixes it being that it's under warranty 8/80
Thanks,
Old Jul 24, 2003 | 07:21 AM
lcf's Avatar
lcf
I think someone else who was consistently getting the P0420 code was told the same thing by a dealership. Ouch, that's expensive.
Old Jul 24, 2003 | 07:26 AM
Tell me about it especially seeing I've only had the car for 5K miles..........
Old Jul 24, 2003 | 09:13 AM
Galo's Avatar
Maxima Pilot
How many total miles on the car and if under
50k miles, should'nt the standard emmissions equipment warranty cover this?
Old Jul 24, 2003 | 09:20 AM
Re: How many total miles on the car and if under
I actually bought it with 56K. It now has 61K
Old Jul 24, 2003 | 09:33 AM
maxi-freak's Avatar
Re: Dealer thinks I need a new Pre-Cat (front pipe)
Thanks,
I wish you the best of luck. I have and have had for some time - the same code. I'm troubleshooting things on my end before I go back to the dealership because I'm not going to pay them a dime!
Please post if you set another code after the seconds PVM flash. I had one done, and the code came back. If it does come back, I recommend checking out your O2 sensors, cause if they check good, then at least you can go to the dealership and get the cat(s) installed under your warranty.
Old Jul 24, 2003 | 09:37 AM
Galo's Avatar
Maxima Pilot
Check out this nugget which is on the EPA
web site....
My summary interpretation is simple....you should be under warranty for this until you reach 80k miles, regardless that you are not the first owner.
Print this, show it to the dealer are see what happens.
The other nugget here is that both on this document and elsewhere on the EPA web site, that MAFs are considered emissions-related items so...has Nissan been screwing us by having us buy MAFs needlessly? Not me, but....many folks here have had to spring for MAFs on stock cars under 80k miles....
Link: http://www.epa.gov/otaq/consumer/warr95fs.txt
Old Jul 24, 2003 | 11:47 AM
Re: Check out this nugget which is on the EPA
web site....
Galo, Is the dual-wall exhaust pipe the same as the "Front Pipe" (what dealer calls the bad pipe). A 600 dollar pipe is a pretty expensive pipe! Part number 20020-34Y00
Old Jul 24, 2003 | 12:02 PM
Galo's Avatar
Maxima Pilot
Benny...not familiar enough with the layout
to confirm one way or the othr but....if that pipe is one piece (integral) with the precat, then by all means, the answer should be yes...
Good luck and please post results of war with dealer...
VQ'ed
69
Aug 27, 2020 12:29 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Balkins
Aug 12, 2015 06:39 AM
BassAddictJ
Aug 4, 2015 11:38 AM
