Go Flush Your Radiator!!!
Old Aug 13, 2003 | 01:13 PM
  #41
Jeff92se's Avatar
I'm needing a caw
You are speaking from ONE example and ONE experience. Other than that, you don't really have any experience. WHAT clogged up the radiator? When was it flushed before? And since you INSIST on saying the coolant was fine, what did it test out at? That's right you don't know the answers to ANY of this. Did you buy a OEM Nissan radiator? If it's aftermarket, maybe THAT'S why you need to flush it every year. Is that what the Nissan FSM says? HAVE you even looked before posting this "change every year"?? Nope again. You ever think the radiator company says change every year to cover their warranty claims?? duh. If they were concerned that their radiator would go bad in ONE year, they would require 6 month changes right?
Like I said, if the Nissan FSM said "every year or every 10,000 miles or so" Fine. At least that's some type of researched answer.
But you just to say "change every year because in my ONE case I screwed up my coolant system" is invalid. Have you ever read anyone else having this issue?? I haven't.
Have you ever thought that it might be something YOU or a previous owner did vs the car??
If you said "check you coolant or check your radiator" fine. But to say someone is going to "***" thier radiator if they don't is pretty ignorant.
I have seen my share of 3-gen radiators. ALL of them have been PERFECT. And they have had no extraordinary care. Does that mean I can spout out that one shouldn't inspect their coolant systems??? NOPE!
Originally posted by jttaylor155
dude, im a perfect example of why you should do this. my coolant was fine!!! over time i got a build up in the radiator. a flush would have fixed it early on. but over time it just built up more and more.
for my new radiator to keep its warranty i have to flush it every year HMMMMMM wonder why that is!!!
maybe because they need to be done.
so stop arguing with people. im speaking from experience you on the other hand are not. if you want to *** up your radiator be my guest
Old Aug 13, 2003 | 01:16 PM
  #42
Jeff92se's Avatar
I'm needing a caw
Especially coming from someone who pride's themselves on posting rice mobiles on .org. And who seems to lack the technical expertise to about coolant systems so thus reverts to childish flames.
BTW, way to be a good example mr moderator!! i started this thread to let people know to flush their radiators so they dont have to replace them like i did. then you come into MY THREAD and start arguing with people about it.
*** OFF!!!
Old Aug 13, 2003 | 01:19 PM
  #43
jeepik's Avatar
For once i have to agree with Jeff92SE here...if you coolant is "fine" there is no need to flush you radiator...
if your coolant breaks down, thats what causes your radiator to clog up...and not even flushing will cure that problem.
the bottom line is..your coolant was not fine..if it was your radiator wouldnt have taken a dump on ya
Old Aug 13, 2003 | 01:21 PM
  #44
stose95's Avatar
Where can you disgard, or recycle the used fluid?
Old Aug 13, 2003 | 01:23 PM
  #45
gizzsdad's Avatar
Originally posted by Jeff92se
Looked fine does not = fine. The only real way to tell is to have it tested or test it yourself.
For what it's worth - I spent some time talking to a guy that owned a radiator repair shop. (He was replacing my wife's at the time.) He said he has NEVER had to replace/repair one that was flushed every year. He also said some people will get lucky and go 4 - 5 years with no problem, but if you want to be sure to not have problems, be flushing every year by the time the car is 3 years old. I haven't been back to see him since!
Old Aug 13, 2003 | 01:25 PM
  #46
Jeff92se's Avatar
I'm needing a caw
Yes that's probably true. To the same extend that you would never have to visit the tire guy for a failed tire if you change them every year.
If one wants to do that fine. I'm just putting a perspective to it.
Old Aug 13, 2003 | 01:29 PM
  #47
MAKSYMALNY
tires and radiators = apples and oranges
nice try.
Old Aug 13, 2003 | 01:30 PM
  #48
Jeff92se's Avatar
I'm needing a caw
tires, brakes, coolant, OIL, etc....
I suggest replacing the pads and rotors every week! You just NEVER know. Better safe that sorry correct?
nice try.
Old Aug 13, 2003 | 01:37 PM
  #49
MAKSYMALNY
No, no, no... please... let's heed YOUR advice and not change ANYTHING until ultimate failure.
Old Aug 13, 2003 | 01:40 PM
  #50
jttaylor155
Like changing the oil every 3,000 miles? Like I said, get it checked. If the fluid is worn out, flush it. If not, why change it?
a flush is not to put clean fluid in THAT WOULD BE REPLACING YOUR COOLANT!!
a FLUSH is to CLEAN the radiator and the whole cooling system!!
i have decided you know nothing about cars.
  #51
Jeff92se's Avatar
I'm needing a caw
You know, instead of trying to flame, why don't you take a look at your owner's manual or Nissan 5th gen FSM. Because since you know best, you SURELY have these technical references correct?
I posted my quick reference already and stated some TECHNICAL reasons as to why I stated what I did. If you want to continue to offer subjective advice based on who you grew up with, go ahead
Old Aug 13, 2003 | 01:42 PM
  #52
Jeff92se's Avatar
I'm needing a caw
Any time you wanna test me go ahead. Wanna put a $20 spot on it too?
Old Aug 13, 2003 | 01:45 PM
  #53
MAKSYMALNY
Yeah, well... there's a difference between being BOOK smart, and being STREET smart.
I'll flush my coolant every year, thank you.
Old Aug 13, 2003 | 01:48 PM
  #54
Jeff92se's Avatar
I'm needing a caw
Please explain the difference I've torn down my VE30DE, done 4-5 clutch jobs, replaced my VTCs when a Nissan mechanic I DIDN'T grow up with couldn't, done 1 engine swap, numerous repairs etc....
What does that make me?? Or better yet,what does that make YOU?
I guess getting that fsm info is just asking too much
Old Aug 13, 2003 | 01:53 PM
  #55
jttaylor155
you know what dude, *** you. i never said im an expert like you think you are.
i was simply saying that i may be a good idea for people to CONSIDER flushing their radiators so they dont have to replace them. the you come in as the high and mighty A hole moderator and say im full of ****. i was simply trying to help others out. thats what this forum is for right.
if this is what this forum has come to (moderators arguing and being dics) *** you and your forum
Old Aug 13, 2003 | 01:56 PM
  #56
jttaylor155
yeah ok!! i used to be in the nba, i was in a rockband, and i banged britney spears and pamela anderson at the same time.
since i just typed that it MUST be true!!
i completely rebuilt the engine on my jeep so i know a little bit about cars.
you dont have to flush your radiator but alot of us will
Old Aug 13, 2003 | 01:59 PM
  #57
Jeff92se's Avatar
I'm needing a caw
Ah okay, leave. Consider this. YOUR the only one swearing up and down getting offended.
ok everyone learn from my mistake!!!
everyone needs to go flush your radiator right away if you havent done it recently. leave work if you have to, just go do it.
Where in the hell does is say or even imply "CONSIDER"????? Backpedaling now? **** me? Naw that's
  #58
MAKSYMALNY
Jeff... hey look... I'm in YOUR boat... have I had actual classes on mechanics? No (unless you call the time spent with my stepdad as 'educational' as he told me about this or had me do that). Am I ASE certified? No. Neither are you. I, like you, would qualify myself as mechanically inclined... at least, since I did almost ALL of the work on my Intrepid (except the tranny stuff), and I have done a lot of the work on both of my Maxes... things that others take to the dealer to have installed. Modding is fun...
So... with that, you claim an expertise based on your experience... I do the same. You keep referring, however, to the RSM or FSM. I'm saying this... I've grown up learning to flush every year. The EXPERT at the radiator shop said he's NEVER seen a radiator fail that was flushed every year (and we did clarify the difference between a refill and a flush). So it does no harm to do so.
I said before... I just don't like criticism... you do it your way, I'll do it my way. Neither one of us is wrong. So don't criticize me for doing it my way... that's like the critics who badmouth Maximas who don't have an aero kit (which some of us don't like)... or a custom sound system (which some of us don't wish to spend $$$ on)... etc.
cool?
Old Aug 13, 2003 | 02:03 PM
  #59
jttaylor155
im actually not technically swearing.
this would be swearing **** you, you pile of ****
im upset cause im trying to help people and you are being a ***** (there no swearing)
Old Aug 13, 2003 | 02:05 PM
  #60
Jeff92se's Avatar
I'm needing a caw
That sounds fine. Thanks. Like I said before, change it every week if you like. It just might be a waste of time if you do. If it tests out BAD and the coolant only lasts one year(based on tests), then go ahead and change it every year. Nothing wrong with that.
Old Aug 13, 2003 | 02:06 PM
  #61
jttaylor155
[/B]
dude i cant MAKE anyone flush their radiator. i was not COMMANDING people to go do it or else. some by me saying go flush your radiator, that is a suggestion. sorry i didnt use the words YOU think i should.
this is cr@p that you whored up the thread i started to HELP PEOPLE!!!
  #62
UMD_MaxSE's Avatar
Got Bent?
Just for reference:
According to FSM: Flush coolant at 60k miles or 48 months and then every 30k miles or 24 months thereafter.
Old Aug 13, 2003 | 02:07 PM
  #63
Jeff92se's Avatar
I'm needing a caw
I'm upset because people are being ignorant. How do you know I didn't just press SHIFT 8 4 times??
So I guess you declined that $20 offer huh?
Old Aug 13, 2003 | 02:08 PM
  #64
MAKSYMALNY
Yeah? The FSM says to change your spark plugs at 100k miles as well.
  #65
Jeff92se's Avatar
I'm needing a caw
Thanks. That only took 5 pages
Originally posted by UMD_MaxSE
Just for reference:
Old Aug 13, 2003 | 02:11 PM
  #66
jttaylor155
its not ignorant dill hole, its diffirence of opinion. its called going above and beyond to take care of your car. does your manual say to wash your car? nope but you still do it to take care of your car. no you might not HAVE to change it every year BUT would be a good idea! the reason for my problem? i just bought the car and the person before me NEVER flushed it.
and what the gay $20 offer about?
Old Aug 13, 2003 | 02:12 PM
  #67
jttaylor155
very good point!! some people take better care of their car then the minumim that is in the manual
Old Aug 13, 2003 | 02:16 PM
  #68
Jeff92se's Avatar
I'm needing a caw
Actually my owners manual does say to wash your car. Oh now your just choosing to avoid that $20 post now?
So tell me, how do you get "change/flush your coolant every year" from "the person who bought it NEVER changed it?" Just because your aftermarket radiator said so(for warranty reasons?) Maybe if the previous owner followed the fsm, you wouldn't be having this problem.
So let me get this straight. Because the previous owner NEVER changed/flushed their coolant, you are now suggesting that EVERYONE that owns a 5th gen change/flush their coolant EVERY year despite what the NISSAN FSM says??
Old Aug 13, 2003 | 02:18 PM
  #69
Jeff92se's Avatar
I'm needing a caw
Who else's day is flying?
Old Aug 13, 2003 | 02:19 PM
  #70
jttaylor155
ok here is my original thread. i NEVER said once a year, that was someone else. i just do it if it hasnt been done in awhile.
mine was never done and now i have to replace my radiator tonight. the radiator is completely stopped up and even a profesional back flush wont clean it out.
i will being taking pictures and making a "how to" on the radiator swap.
here is the thread where i talk more about the problem and the whole process of figuring out what was wrong.
  #71
MAKSYMALNY
Jeff... I'm saying this... my 5th Gen was mine, brand new (10 miles on it at delivery).
We can talk more in several years and see how things are doing.
Old Aug 13, 2003 | 02:20 PM
  #72
jttaylor155
by the way i added this to my original post so people dont waste their time
WARNING!!!
IF YOU ARE READING THIS THREAD FOR THE FIRST TIME TO FIND OUT ABOUT FLUSHING YOUR RADIATOR...DONT WASTE YOUR TIME GOING THROUGH THE 5 PAGES. Jeff92se WHORED UP MY THREAD ARGUING WITH PEOPLE.
THIS IS JUST A SUGGESTION TO HELP PEOPLE OUT. YOU DONT HAVE TO GO FLUSH YOUR RADIATOR. I JUST THINK IT WOULD BE A GOOD IDEA.
Old Aug 13, 2003 | 02:23 PM
  #73
UMD_MaxSE's Avatar
Got Bent?
mine had 6 miles when I bought it. It has 54k+ miles on it now and it is less than 3 years old. I've not yet flushed the coolant. The coolant 'looks' fine and the level has never really changed ever. I guess I will see what happens when I go change it in a little while.
By the way, I replaced the plugs at 46k miles just for kicks...
Old Aug 13, 2003 | 02:25 PM
  #74
MAKSYMALNY
Shame on you... that's not following the FSM.
Jeff... give him 30 lashes with a wet noodle.
Old Aug 13, 2003 | 02:26 PM
  #75
Jeff92se's Avatar
I'm needing a caw
My FSM says to change the platinum plugs every 60k. So that's what I did.
Old Aug 13, 2003 | 02:27 PM
  #76
UMD_MaxSE's Avatar
Got Bent?
I don't want Jeff and his wet noodle anywhere near me
Old Aug 13, 2003 | 02:28 PM
  #77
MAKSYMALNY
By the way... what UMD school is it?
Is that mascot the "Fighting Turtles"? (snicker)
Oh yeah... or maybe it's the "Snappers"
Old Aug 13, 2003 | 02:31 PM
  #78
UMD_MaxSE's Avatar
Got Bent?
UMD College Park...
it's the terrapins
Old Aug 13, 2003 | 02:34 PM
  #79
MAKSYMALNY
Well I'm a Badger(!)
Hah!
Terrapin? Hmmm:
"Any of various North American aquatic turtles of the family Emydiolae, especially the genus Malaclemys, which includes the diamondback terrapin"
Old Aug 13, 2003 | 02:36 PM
  #80
Jeff92se's Avatar
I'm needing a caw
Quit harrrrrrrrrrr'ing up JT's post. Or he might include you in his first post! HARRRRRRRRRRRRRRRRRR!
