Need to change tranny fluid and belts
Old Oct 14, 2003 | 06:57 AM
  #41
dave's Avatar
tranny fluid change. this is something i need to do too. just some questions in addition to all this info. i have a 2K 5SPD, 30,000 miles.
1. with a manual transmission, (after initial draining) will pumping the clutch (with engine off) force the remaining fluid out - at which point i can replace the bolt and fill with approx. 11 quarts trans fluid?
2. (i have 30,000 miles) is cleaning the drain pan/magnets necessary?, i'd prefer to wait till 60,000.
2a. is cleaning the drain pan/magnets necessary if i switch to mobil synthetic transmission fluid?
3. is there a difference in transmission fluids between an auto and manual transmission?
thanks for the help/advice.
one more. has anyone used a transmission oil additive (such as militec-1 ) in their transmission fluid? would you consider/recommend it?
Old Oct 14, 2003 | 02:13 PM
  #42
woreyah's Avatar
Wait a minute! No one has mentioned how to drain the fluid from the torque converter. That's probably where the $400 cost is coming from.
Old Oct 14, 2003 | 05:23 PM
  #43
woosh's Avatar
Dave,
The process is different for a 5spd. Most ppl like MT-90,a amsoil both very good synthetic oil.
woreyah,
The part where the clear vinyl tube is attached, is the section to remove the fluid from the torque converter.
100% synthetic blood, say when.
SHIFT_woosh
Old Oct 14, 2003 | 07:47 PM
  #44
BLaZin 2k MaX's Avatar
Wow this post came back from the dead that reminds me I still have to do this.
Old Oct 15, 2003 | 04:08 AM
  #45
ppetruccelli's Avatar
Don't need a flush unless you haven't been maintaining your tranny properly. Simply unscrew the plug, drain, and refill with Amsoil synthetic. The belts are tough to do though, but can be done with time and patience. But, again, your belts should be fine unless you are around 100,000 miles.
Old Oct 15, 2003 | 05:37 AM
  #46
dave's Avatar
Originally Posted by woosh
Dave,
SHIFT_woosh
Thanks, I spent more time searching, and found Pioneer's write-up: Manual Transmission
now, on to brakepads/rotors...
Old Oct 15, 2003 | 08:48 AM
  #47
Torque Converter
Is is possible to drain the torque converter without taking apart the tranny? If so, how?
pktaske
May 6, 2016 07:49 AM
markevans999
Oct 25, 2015 08:27 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
