greddy exhaust question
Old Sep 24, 2003 | 05:53 AM
2kprlmax's Avatar
Hey I just installed the greddy evo but I have a question. When I am at a light i like to step on the gas to hear the exhaust onlty problem it that I hear the noise pretty much underneath the drivers side. I had my brother stand behind the car and he really didn't hear the grumble, he said it was coming from under the car. Could something be loose or not on correctly?
Old Sep 24, 2003 | 06:57 AM
sorcereur's Avatar
what kind of noise. At least describe that.
If it's the exhaust sound, then that's normal because you're closer to the driver's window. So you'll hear it from there. And vice versa if you were in the passenger seat. That's how it is with my HKS. But describe the sound you're talking about.
Old Sep 24, 2003 | 07:01 AM
PIONEER's Avatar
The metal Gasket that goes b/w the B-Pipe and Cat. Did you make sure that gasket is not busted. Make sure the B-pipe and Cat connection is Tight, and Also B-Pipe to Rear section is tight. You used good gaskets right. Paper/cardboard would burn out b/c of heat and cause a leak.
Old Sep 24, 2003 | 10:40 AM
2kprlmax's Avatar
at some points the car does smell like something was burning
Old Sep 24, 2003 | 10:44 AM
Y2KSESteve's Avatar
New exhaust systems often smell funny after installation. Possibly check your Y-pipe connections a well.
Old Sep 24, 2003 | 11:00 AM
PIONEER's Avatar
You didn't break the Flex did you
Old Sep 24, 2003 | 11:44 AM
2kprlmax's Avatar
i didn't install it i am going back to the spot to have them check it out today
Old Sep 24, 2003 | 01:29 PM
sorcereur's Avatar
Also make sure that the bolts are tightened up and no gap in between the B pipe and the muffler piece, and before the Bpipe. Because if even a slight bit of air escapes in between the exhaust noise will get louder.
Old Sep 24, 2003 | 02:44 PM
Darth Vader's Avatar
^ Yup, be sure everything is tight. If it was loose, the heating will make it even more loose than b4.
Old Sep 24, 2003 | 05:32 PM
2kprlmax's Avatar
Well I went to the shop and the guy listened to the car and he was like it may be the gasket. They were going to get another and do the job on friday.
Old Aug 22, 2005 | 11:42 PM
wcasskicker's Avatar
I just removed the metal gasket between cat and b-pipe, and found out that the gasket is broken in 2 pieces. Where can I get a new gasket? Will the stock gasket work or should i order from Greedy?
Old Aug 23, 2005 | 05:09 AM
Puppetmaster's Avatar
You can either get one from GReddy or from an autoparts store... those are 2.5"... the stock gasket is smaller.
Old Aug 23, 2005 | 10:05 AM
Thanx for the prompt reply or else I can't drive my baby!
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
