For 2k2+ owners who has lowered their Maxima's
Old Sep 24, 2003 | 07:47 AM
soundmike's Avatar
Very sound, Mike
Did you have to re-aim your headlights? If so, how did you do it?
Judging from photo's here on the .Org, i can only imagine how much less the light output throws itself in front of the car.
Given that i drive a lot of dark side roads (e.g. no street lights), having them not put out light as far as it does is just dangerous for me.
Thanks.
- Mike
Old Sep 24, 2003 | 07:53 AM
MaximaMan77's Avatar
There's a white plastic nut on the back of the headlight housing. Get a 8mm socket and a tiny rachet. Find a nice light colored wall on a flat surface, give yourself about 6-8ft between the front of the car and the wall.
Old Sep 24, 2003 | 07:54 AM
soundmike's Avatar
Very sound, Mike
Cool. Sounds simple enough. Thanks
Old Sep 24, 2003 | 08:01 AM
NP.
I've got a tiny scoket set. It's got a small ratchet and extensions. I kept it in the console for a while to do fine adjustments as needed till I got what I liked. If you have one I'd do the same. GL
Old Sep 24, 2003 | 08:28 AM
chigga's Avatar
do you have to re aim them when you drop your ride. im dropping mine this weekend and this would be good to know
Old Sep 24, 2003 | 08:36 AM
Nissan sells you the car with them already pointed down a good bit. (Less glare for other drivers) So after dropping it will only be worse. This is very easy to do though.
Old Sep 24, 2003 | 08:39 AM
soundmike's Avatar
Very sound, Mike
I'll play around with my lighting later tonight, t'was a good idea to keep the tools handy in the glovebox btw
Old Sep 27, 2003 | 03:10 PM
griffy2k2max's Avatar
Thanks.
- Mike
I didn't notice any deminished lighting issues, I drive through some pretty dark areas from time to time, didn't re-aim my lights at all.
Old Sep 27, 2003 | 05:05 PM
Bluesbrekr's Avatar
Doctorate in Detailing
I noticed the same thing...that even with the factory springs the headlights were a bit low. After installing my Maxspeed's, I raised the beam. Much better illumination. I don't think they're too high, cause I haven't had oncoming traffic flash their hi-beams at me.
Old Sep 27, 2003 | 05:23 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
When i dropped it, i noticed i could see more of the road much better near me, but it wasnt' shining the road like it used to. I aimed them up a bit and now it's perfect!
Old Sep 27, 2003 | 09:21 PM
soundmike's Avatar
Very sound, Mike
Just what i wanted to hear, the roads i drive through now is pretty dark that i tend to use the highbeams a lot more often.
But then i figured, if i can re-aim my headlights just a bit higher i'm going to be better off. Dropping the car would just make things worse for me if i don't readjust the lights accordingly.
Old Sep 28, 2003 | 03:55 AM
Triple8Sol's Avatar
I miss the .org!
I've been needing to do this for awhile now...it wasn't really noticeable with the Maxspeed drop, but now on Tein's it's very pronounced. I've got a writeup I found somewhere if you need it
Old Sep 28, 2003 | 06:10 AM
Audtatious's Avatar
Bandwagon Lover
Interesting...I never really thought about reaiming the lights after the drop. The HID's do so much better than regular bulbs, I could still see plenty. Guess I will have to try my hand at adjusting them too
Old Sep 28, 2003 | 08:11 PM
Eat Naaawwwzzzzz
Just make sure to do it correctly. Bad HID aiming is not nice at all
Old Sep 28, 2003 | 09:47 PM
limsandy's Avatar
http://www.autooptiks.com/aiming.html
~limsandy
Old Sep 28, 2003 | 09:55 PM
Triple8Sol's Avatar
I miss the .org!
Originally Posted by limsandy
That's the one I printed out before...
CRizz
41
Jun 7, 2021 05:42 AM
tcb_02_max
Sep 11, 2015 12:23 PM
twotonezed
Aug 16, 2015 08:10 PM
altome15
Aug 10, 2015 07:05 PM
