idle question
Old Oct 7, 2003 | 02:16 PM
Maxnut's Avatar
idle question
My 03 GLE has 23k miles on it. When my car was new, it idled at 500 rpm. Now it idles at 700 rpm and I can feel a slight vibration when I have my hand on the steering wheel. I am taking the car into the dealer tomorrow for service. I plan on having then do the hesitation tsb, check the coils and maf. Is there anything else I should have them check? Does anyone else have a slight vibration in the steering wheel? The vibration is a kind of sputter that lasts for about 1 second, pauses for a second and sputters again. Although it is a small increase, I am still concerned about the idle speed. Any thoughts? Thanks.
Old Oct 8, 2003 | 05:20 AM
Maxnut's Avatar
***bump***
Old Oct 8, 2003 | 05:27 AM
2k2MerlotSE's Avatar
JUVIN's ride
I am not sure what it is but my 2K2 has 17000 miles and it does the same thing. I am taking mine in for the MAF,hesitation,bose cutout,and cold start up rattle.
What coil TSB are you talking about?
Old Oct 8, 2003 | 06:42 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
500 is too low of an idle for an auto. at least all that i have been in. my idle is 725 but if you are experiencing vibration then i would have it checked out.
Old Oct 8, 2003 | 06:43 AM
Jabiddy780's Avatar
I have a 2k w/ 38k miles on it....i idle at about 7 and have a very slight vibration ...I just thought that was normal
Old Oct 8, 2003 | 07:03 AM
MaScott's Avatar
Check out your Owner's Manual, my Max2K idling speed is supposed to be at 550-650. So, 700 rpm is not that far out of range.
Old Oct 8, 2003 | 11:05 AM
sloppymax's Avatar
are you manual though? they will idle lower than autos do. i actually had mine bumped up to address an issue with my udp. went from 700 to 725 but i dont have any noticeable vibration.
Old Oct 8, 2003 | 06:57 PM
MaScott's Avatar
Yep, I am.
Old Oct 8, 2003 | 09:58 PM
WILLSE's Avatar
maybe a bad motor mount? i can feel my car jump a bit at idle ... i have a bad rear mount hopefully reaplcing it will fix it....
will
Old Oct 9, 2003 | 05:24 AM
MaScott's Avatar
will
I doubt that...
My guess would be you've got a misfire, maybe more than in one cylinder. Do this quick check by disconnecting injectors one after another, you'll see which cylinder is dead.
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
