solution to ping/knock
Old Oct 21, 2003 | 08:11 AM
mille_3's Avatar
Hey guys
For those of you that have the pinging/knocking problem..... After taking my car in for the 6th time they finally got it right!!! All that needs to be done (in my case anyway) is to set the base idle back 2 degrees. Now, this is NOT the same as setting the timing back(for those of you who don't know) Have your dealer check that out and it MAY be the solution for you.
Old Oct 21, 2003 | 08:40 AM
maximadave's Avatar
detailerdaveb@gmail.com
base idle? Was does your car idle at?
Old Oct 21, 2003 | 09:37 AM
Cdriven's Avatar
Originally Posted by mille_3
Hey guys
Thats interesting. So, if they set your idle back, what does your Max idle at now? Does the car feel the same, just without the ping?
Old Oct 21, 2003 | 09:44 AM
klarsen's Avatar
Hey guys
I don't ever get knocking/pinging on the idle. Only on heavy loads in 2nd or 3rd gear at 2000-2500 RPM. Was that the same scenario you had??
Old Oct 21, 2003 | 09:47 AM
mille_3's Avatar
it's about 50 rpm lower right now, hardly noticeable. It might be imaginary since I've had all this crap going on and I just want the car to drive better, but it seems to be pulling nice and even throughout the whole rpm range. This approch doesn't make any sense to me either but I don't really care since it cured the ping.
Old Oct 21, 2003 | 09:48 AM
mille_3's Avatar
Same as you and everyone else with this problem. As I said in the above post, this approach doesn't make any sense, but it works.
Old Oct 21, 2003 | 09:53 AM
klarsen's Avatar
Thanks, I'm going to give it a shot at the dealer. Did they charge you for it, or threw it in becasue you've been there so frequently?
Old Oct 21, 2003 | 09:55 AM
mille_3's Avatar
I've got 10k on the odo, so it's still warranty.
Old Oct 21, 2003 | 11:00 AM
Cdriven's Avatar
Funny thing is, when I do take my car into the dealer for them to check that, they'll have to look at every other solution first...
This could take a few weeks...
doctorpullit
Apr 23, 2017 05:35 AM
homewrecker
Sep 23, 2015 03:41 AM
jchronis2552
Sep 21, 2015 05:52 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
maximusrising
Sep 4, 2015 06:31 PM
