Need to make sure this is right (HID's)
Old Oct 22, 2003 | 02:56 PM
LithiuMax
My friends say that they have a buddy who can get an upgraded kit for my HID's, so that they will be a higher K rating (7000 and up, I believe). They say regularly, it's around $500 or so, but they can get it for $300. They also say that I need a special upgraded kit for this, and I cannot just buy 7000K and up bulbs and put them in there (which, I imagine, would be cheaper than $300). So I have 2 questions:
Who is right - do I really need new harnesses and such for a hiher K rating bulb? And also, if they are right, is $300 considered to be a good deal? Thanks.
Old Oct 22, 2003 | 02:58 PM
redstradic's Avatar
yes and yes since the GD Deals are going around $330
Old Oct 22, 2003 | 03:11 PM
MacAlert's Avatar
All you need are new bulbs. No need for the while kit.
Old Oct 22, 2003 | 03:22 PM
LithiuMax
Hmm, two answers that conflict with one another... so which is it?
Old Oct 22, 2003 | 03:41 PM
redstradic's Avatar
well i know the price seems right, as far as the wiring harness goes, not sure if those new bulbs will either fit and melt your oem wiring harness
Old Oct 22, 2003 | 04:01 PM
soundmike's Avatar
Very sound, Mike
Kelvin rating only changes the colors and not the output - so i'm assuming it will put out equal or less lumens. Which means, it's probably using the same - if not less - power than the OEM.
That said, you only need the bulbs.
Old Oct 22, 2003 | 04:07 PM
Jeff92se's Avatar
I'm needing a caw
Yup. higher K value is just different color. Higher k does not = higher wattage/light output
Old Oct 22, 2003 | 04:16 PM
LithiuMax
Thanks for the info!
Now, I have another inquiry: is it possible, given what you have told me, that my friends are talking about something that has a higher K rating AND a higher light output, and consequently a higher wattage which would need new harnesses and such?
Old Oct 22, 2003 | 04:26 PM
MacAlert's Avatar
No, they're referring to an HID retrofit kit. You don't need that.
Old Oct 22, 2003 | 04:28 PM
LithiuMax
What's that? What does it do? How come I don't need that?
Old Oct 22, 2003 | 04:30 PM
MacAlert's Avatar
Cause you already have HID's in your car. He's referring to cars that don't have HID's.
Old Oct 22, 2003 | 04:45 PM
LithiuMax
The guys I am talking about are pretty knowledgeable, and they know I have HID's. They called it an "HID upgrade."
Old Oct 22, 2003 | 04:57 PM
soundmike's Avatar
Very sound, Mike
Ask them to describe what the "upgrade" entails. Then ask them to describe the HID system in your car.
Chances are, there's not much to the so-called "upgrade".
Old Oct 22, 2003 | 06:50 PM
MacAlert's Avatar
No offense but they are obviously not knowledgeable here. You car already has HID's and an UPGRADE that costs $500 is going to give you what? HIDs with a higher Kelvin. You can go spend $500 to get the same effect ~$150 for new bulbs will get you. Ask anyone who changed their bulbs here and they will tell you the same.
Old Oct 22, 2003 | 06:51 PM
NT2SHBBY
put it like this; you got it all- D2R capsules, ballasts, ignitors, wiring
if you wanna upgrade, you swap D2R or modded D2S capsules (bulbs) only....
I had KOPS 6000k bulbs which were purple and now I run KOPS 7000k D2S modded bulbs which are blue with a hint of white
Old Oct 22, 2003 | 07:14 PM
maxup02's Avatar
what if you still want your light to be white mostly, but the main goal is over all brightness and output? what kind of bulbs are the one to go with?
Old Oct 22, 2003 | 07:18 PM
NT2SHBBY
brightest and most output are stock......
best looking.....different story
Old Oct 22, 2003 | 07:34 PM
hockeyboy82's Avatar
body kit question
oops i posted in the wrong thing now im gettin rid of it...sorry
Old Oct 22, 2003 | 07:52 PM
maxup02's Avatar
anybody seen this guys thread? somebody help him
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
MaxLife17
Sep 8, 2015 02:36 PM
