stillen intake help!!
Old Oct 22, 2003 | 07:21 PM
tdogg169's Avatar
Just intaked my stillen intake in a 2k2 max. But when I start my car, it goes dead. When it does stay on, I press the gas and it boggs down. Does anyone know why??
Old Oct 22, 2003 | 07:27 PM
Darth Vader's Avatar
Sounds like MAF sensor is not functioning correctly, can you post photos of your install ???
Old Oct 22, 2003 | 07:52 PM
tdogg169's Avatar
I don't have my camera with me. Why would my MAF not function right?
Old Oct 22, 2003 | 08:01 PM
Well from reading many post on this site, there have been MAF's that have gone bad after install, When they go bad, the car runs poorly. Infact, I just had mine replaced under warranty recently. I am not familiar with your intake. Check all connections and make sure it is tight. Some of the more expireenced guys will read this and reply so hang tight.
Old Oct 22, 2003 | 08:50 PM
tdogg169's Avatar
Thanks Darth for the help. That was it. My MAF sensor had oil on it from the **** I put on the K&N filter. I cleaned the MAF sensor off and wow! True power is starting to come out of my max now!
Thanks!!
Old Oct 22, 2003 | 09:30 PM
MaxVader's Avatar
Thanks!!
How did you clean the sensor??????!!!!!!!!!!
Old Oct 23, 2003 | 03:32 AM
tdogg169's Avatar
I wiped it with a towel and blew on it real hard.
Old Oct 23, 2003 | 04:54 AM
Thanks!!
Wow, good news, you are fortunate. Sometimes oil on the MAF can ruin it. You must have cleaned it before it could foul. Congrats and enjoy that power and sound.
Old Oct 23, 2003 | 04:57 AM
ToYLeT902's Avatar
JET Speed Lab
Nothing like a good blow job to get your car up and runing eh?
Old Oct 23, 2003 | 05:19 AM
MIKE2K2's Avatar
Custom User Title
Did you add more oil? The Stillen should come pre-oiled, just install and go. If you did add more you should try to get as much off as you can some how, because it probably will happen again.
Old Oct 23, 2003 | 05:32 PM
Cdriven's Avatar
Too easy!
Old Oct 23, 2003 | 05:44 PM
tdogg169's Avatar
Yes, i did add more oil, and yes it happen again. Every time i stop i take the MAF out and blow it off. I also tried a qutip. It worked great. Just be real carefull when i stuck it in the little hole as not to bend the wire. It seems to be working fine now.
Old Oct 23, 2003 | 05:48 PM
Cdriven's Avatar
Good deal!!
How do you like the Stillen Intake? I was going to get the Stillen, but decided to go w/ the Injen instead. Does it come with a heatshield?
Old Oct 24, 2003 | 06:29 PM
tdogg169's Avatar
I like great, but from reading all of post i think the injen might be better. I just did not want a cold air intake. Had one in my 91 acura integ. and water got in it.
Old Oct 24, 2003 | 06:47 PM
Cdriven's Avatar
I've grown to like my Injen intake. But its not a true cai in that it sits in the engine bay with the filter right below the battery. So, the only way to get water in it is to really drive through very deep water. It might be more expensive than the stillen. I paid like $250 from SWA.
It does look great though!
Old Oct 24, 2003 | 07:17 PM
asu174's Avatar
Clay Aiken has fancy genitals
It comes pre-oiled. You essentially ruined the filter. Your MAF is going to permanently fail very, very soon.
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
maxima297
Sep 30, 2015 03:32 PM
MichMaxFan
Sep 30, 2015 09:18 AM
