DDE Lightning™ --- | STRIKES | |\/|@\/||\/|@
Old Jan 18, 2004 | 11:40 AM
  #481
umnitza's Avatar
Former Sponsor
I need pictures or descriptions in email.
That way there is a trace.
Old Jan 18, 2004 | 11:41 AM
  #482
umnitza's Avatar
Former Sponsor
Originally Posted by studman
Everyone: I saw these in person on Manaz101's car last night. They are 10 times better than the pics show. After seeing them, I'm ready to order as well.
Umnitza: How should I go about ordering a set?
You can call us tomorrow or just do it over the web site
Old Jan 18, 2004 | 11:42 AM
  #483
umnitza's Avatar
Former Sponsor
we have not had 2 ballasts go bad ever like this.
So, I'm confused and concerned.
Old Jan 18, 2004 | 11:47 AM
  #484
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
when can i expect mine... my account name is bbeeler12 at aol dot com.... order a lil over a week ago... let me know thanks
Old Jan 18, 2004 | 01:29 PM
  #485
Playero's Avatar
Sanduguero
Originally Posted by Lefty_gunz187
Playero, it didnt work. The wire is still burning
you should of came here for the install, we could of done it at the same time........
Old Jan 18, 2004 | 03:10 PM
  #486
jaco's Avatar
Does anyone know where are the instructions?
I tried http://www.umnitza.com/ddelightninginstallmaxima.htm
and it doesn't work. I only found Gen V instructions on their website.
Thanks for help.
Old Jan 18, 2004 | 06:41 PM
  #487
Lefty_gunz187's Avatar
I told you that before and you said nah, that i should be alright. Its all good. I dont think it was something i did wrong. That whole side would have been bad if that is the case. Everything else lights up fine as well as the one that was connected to the jacked up wires. There has to be soemthing wrong with the ballast
Old Jan 18, 2004 | 10:29 PM
  #488
Playero's Avatar
Sanduguero
i said youll be alright, i did not say you cant come here and do it at the same time...and if i did my fault!
Old Jan 19, 2004 | 01:37 PM
  #489
Its all good. Im not sweatin no petty stuff, it wasnt all that hard anyway. Maybe we can meet up one day.
Old Jan 19, 2004 | 04:24 PM
  #490
umnitza's Avatar
Former Sponsor
Ok, sorry for the latest update
Our shipments are delayed again - why?
We spent 20 hours isolating the correct colors on all the rings because our suppliers mislabeled 90% of them.
So, that's why some of you who have purchased in the next batch have not received yours, dont' worry, we will make the shipping correct this time.
One other thing, we are going to insure that problems with the packages don't arise any longer.
If you give us til Next Monday, you will be happy.
For spare parts, that's also the next time I'll have a bunch to ship.
After that, no issues at all from then on out.
I do not get updates on this thread, if you need help info@umnitza.com
Old Jan 19, 2004 | 05:55 PM
  #491
2k2nyc's Avatar
Mine just shipped today. One is broken
Old Jan 19, 2004 | 09:51 PM
  #492
Fezzik's Avatar
Well I got mine in last friday, i didnt haven any adhesive on the ends of my rings, so i went and bought all weather double sided foam tape at home depot. rated 5 lbs. Worked great though. Sometimes the lights will light up right, and sometimes. they will remain that purplish color. So i said forget it and I'll talk to Umnitza tomorrow. Well i put everything in and have to go to a dinner party and presto they are working great? what's up with this. lol oh well they look great and sexy as can be
Old Jan 19, 2004 | 10:17 PM
  #493
umnitza's Avatar
Former Sponsor
So, the reason we have issues with breakage is two fold
1) my shipper isn't putting sticky labels of Fragile on them.
2) our box is being tossed around like a lame duck.
BTW - guys, we have completely caught up with shipments.
We have about 12 units in stock finally.
So tell me, was the install difficult? Doesn't seem to have been, too many of you are saying you've had no problems
Old Jan 20, 2004 | 09:06 AM
  #494
Manaz101's Avatar
I don't think the install was too bad....only issue i had was since i don't have an intake i had to velcro the "black box" to the battery. There wasn't enough room for it to screw into the battery tie down bolt, the OEM airbox was in the way. I also couldn't move the box due to the wires being the length they were. Once i did find another spot one wire did not reach a proper mounting point, i ended up running the ground wire over the air box, guess that'll change when i drop in my intake. Besides that no problems here, except for my ignorance in testing (thanks for the help Matt!).
Old Jan 20, 2004 | 12:28 PM
  #495
2k2nyc's Avatar
Where can I download the installation guide???????
Old Jan 20, 2004 | 01:01 PM
  #496
Fezzik's Avatar
You can connect the ground wire to the negative battery lead. I also have the stock airbox and had problems finding a ground cause the chord wasnt long enough.
Old Jan 20, 2004 | 02:53 PM
  #497
Fezzik's Avatar
I've gotten a lot of questions on how to test the DDE's so here is short write up. It's a lot easier than it looks on here.
To test the dde's:
First you will test at one time 1 ballast and 2 rings (big and small ring) There are 4 white wires coming out of the ballast to 2 plugs. Plug the rings into each plug. (One ring per plug) On the end of each wire coming off of the ring is a metal connector (that will later plug into the black plugs provided) Plug these metal ends into each connector. Doesnt matter which way. Make sure there is a good connection and if any metal is hanging out, cover it up with electrical tape temporarly. You do not want the two connector to touch when you are testing the rings out. Now you have the rings plug up to the ballast. Now out of the ballast is 2 more wires. A red and brown. Touch the brown with the negative (ground) and the red with the positive. Be sure your not touching any metal with your fingers. The rings should light up.
Edit: I'll post a pic of it:
Hope this help guys.
Old Jan 20, 2004 | 08:06 PM
  #498
Manaz101's Avatar
So you connected the ground to your negative battery post?
Old Jan 21, 2004 | 12:27 AM
  #499
Fezzik's Avatar
Yep sure did. Not a single problem. It's the same thing. you can jump a car using the negative battery lead (so long as its hooked up) or find a ground somewhere on the car like a strut bolt.
Old Jan 21, 2004 | 02:53 AM
  #500
umnitza's Avatar
Former Sponsor
Fezzik, thank you, but there are detailed instructions in step 4 of the install guide.
yes, the guide is hidden behind a password
Old Jan 21, 2004 | 05:53 AM
  #501
MannyNJ2k2max's Avatar
could there be a reason why all the rings dont light up (even after car is running& warm) It has been 15-35 degrees this past week- I'm really ticked.....
they havent been lit up like they are supposed to since the night of the install....
Old Jan 21, 2004 | 10:21 AM
  #502
Playero's Avatar
Sanduguero
Here you go brother!
Quote:
Originally Posted by Pearl96Max
matt- its mannynj2k2max- i installed the rings- they were bench tested- were fine- but now one side looks purple (and dim)and the other side looks fine- whats up?
I had the same exact problem when I first installed mine...IGOR911 did as well, and he came up with the solution..its all in the connectors (black clips, male/female ends), simple solutions is to cut the connectors and hard wire the wires together..for some reason the black connectors are "doodoo" and somehow block most of the current..I did it and dont have that problem anymore..
Old Jan 21, 2004 | 01:24 PM
  #503
LeftCoastTuning's Avatar
When you say "hard wire" you're splicing the wire and using your own connectors right? If not, could you explain?
Old Jan 21, 2004 | 01:44 PM
  #504
MacAlert's Avatar
I think he means splice both wires and plug them together without using any connectors.
Old Jan 21, 2004 | 02:02 PM
  #505
Playero's Avatar
Sanduguero
Originally Posted by MacAlert
I think he means splice both wires and plug then together without using any connectors.
Exactly!
Old Jan 21, 2004 | 02:11 PM
  #506
Exactly!
Me and Don did this on one headlight and occasionally one of the rings will do the same thing....its not something easily pinpointed.....i have different rings
light up fine/focked up at different times...
Old Jan 23, 2004 | 11:47 PM
  #507
umnitza's Avatar
Former Sponsor
They do not like the cold.
Mine do that as well. They need time to warm up.
Additionally, hard wiring = soldering. While it's not advised for the average person, if you know how to solder, by all means, go ahead.
We've solved so of those issues, but we haven't eradicated them.
We're working on it though
Old Jan 24, 2004 | 01:49 PM
  #508
Edward Lee's Avatar
Oops, I broke one of my halo's. Be very careful on the installation. These things are very fragile. One of my high beam halo's was a little bit smaller than the other high beam halo. Realizing that they had a little flex to them I spread the smaller one out just by a hair w/a piece of cardboard and mounted it . When I went to place the 1/2 lb weight on the halo I noticed that the cardboard was in the way, so I made a new piece of cardboard to spread it out in the middle instead of at the mounting points, snap, it was all over. Lucky for me Matt was in the office and is sending me another one. I should have it by Monday. A costly lesson! Just mount the halos and don't worry if they don't fit right on the edge. It is ok if they ride the inside a bit.
Old Jan 25, 2004 | 11:32 AM
  #509
umnitza's Avatar
Former Sponsor
Edward, shipped your ring yesterday, you should have it on Monday
Old Jan 25, 2004 | 01:08 PM
  #510
K Pazzo 6's Avatar
Matt....YGM
Old Jan 28, 2004 | 10:25 AM
  #511
umnitza's Avatar
Former Sponsor
Edward, did you get the ring.
KP, did you get the ballast?
Old Jan 28, 2004 | 11:00 AM
  #512
studman's Avatar
Mine should be here tomorrow. This is gonna go good with my headlight project.
Old Jan 28, 2004 | 11:30 AM
  #513
Edward Lee's Avatar
Got the ring as promised, If anyone breaks their ring be sure to save the little plastic mounting tabs. I had to dig mine out of the trash when my new ring showed up without them. It was a dirty job. I don't think that the replacement rings are going to have the mounts on them. Take yours off your broken ones to be on the sfe side. Matt you guys need to do something about those connectors. Sometimes my rings don't light up like they should and I have to giggle the connectors to get them to light up correctly. I guess I am going to change the connectors to something that is a bit more reliable.
Another question. Is there any reason why the rings aren't more of a complete circle. I mean they stop a bit short of where the light bezel ends its radius or curve. It would be nice to see these things go all the way around or at least up to where the headlights end their radius and straighten out at the top.
All I need are some eyelids to complete the look. By the way, these things are insane looking.
Old Jan 28, 2004 | 11:31 AM
  #514
umnitza's Avatar
Former Sponsor
Because it's the top of the light + it's the way (engineering wise) we have to make it
Old Jan 28, 2004 | 11:35 AM
  #515
Edward Lee's Avatar
Cool, I can more than live with the incomplete circle.
Both lights are sealed and working perfect.
Old Jan 29, 2004 | 01:10 AM
  #516
umnitza's Avatar
Former Sponsor
hmmm, pictures
Old Jan 29, 2004 | 08:20 AM
  #517
Edward Lee's Avatar
I don't know how to post pics in this forum. I think that I need a site to direct the pic to. I'll email it to you and maybe you can post it for me.
Old Jan 29, 2004 | 09:39 AM
  #518
umnitza's Avatar
Former Sponsor
sure, do that
Old Jan 30, 2004 | 12:03 AM
  #519
umnitza's Avatar
Former Sponsor
pics from edward?
Old Jan 30, 2004 | 08:25 AM
  #520
Edward Lee's Avatar
Hi Matt,
I was going to send you a pic of the light out of the car but I decided to send you pics of the DDE's fuilly installed. I did everything except clear out the orange ring, including painting the inside satin black. I looked for that damn light at home depot and couldn't locate it. Today is Friday and I am heading down to my garage to install into the vehicle. I will fire off some pics later this afternoon. Everthing looks really good! I can hardly wait.
Edward
