SES light
Old Dec 11, 2003 | 06:13 AM
jleetkd's Avatar
SES light
My SES light has been on for about two weeks now and I know what the problem is. It is my exhaust. A brief history on the car: It is a salvage title car that was involved in a flood. The car is configured for the California Emission Standard. The ECU was damaged in the flood and was replaced with a standard ECU. Therefore due to a mismatch, I get bad exhaust codes. I live in Nebraska and there are no emissions standard so it would be a waste of money to spend 1000 dollars to correct the problem.
This morning, the SES light turned itself off. Can it do that? Is this good news or is there a problem waiting to happen? I always thought if a light comes on, the only way to turn it off was to clear out the codes.
Thanks!
Old Dec 11, 2003 | 09:48 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
So you're saying you have a FED spec ECU in your Cali-spec 2000 Maxima and it acts fine except for the SES light?
Thanks!
Old Dec 11, 2003 | 11:28 AM
jleetkd's Avatar
According to what the dealership said yes, I do have a FED spec ECU my Cali spec 2000 Maxima. From what I was told, the FED ecu cannot process the extra rear O2 sensors causing it to trip exhause codes. The light was off this morning and I didn't do anything out of the ordinary to cause that to happen. The car runs great, I have not experienced any problems since having the coils replaced.
Old Dec 11, 2003 | 11:40 AM
IceY2K1's Avatar
Thanks that's VERY very good news for the Cali-spec 2000s that might be wanting a TechnoSquare ECU someday.
Sorry, not really helping you.
Old Dec 11, 2003 | 11:45 AM
UMD_MaxSE's Avatar
Got Bent?
the swirl control valves all work correctly with a fed spec ECU?
Old Dec 11, 2003 | 02:25 PM
jleetkd's Avatar
I have no idea. Would that put out an error code? The only error code I get when the SES light comes on as of late, are exhaust codes.....
Old Dec 11, 2003 | 03:43 PM
zman187's Avatar
what code is it?
Old Dec 11, 2003 | 05:21 PM
UMD_MaxSE's Avatar
Got Bent?
well, the ECU will not trigger a code because the fed spec ECU has no knowledge of the swirl control valves since they are only in cali spec cars. I was just wondering if they would still function correctly with a fed spec ECU... most probably they do...
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
