Rotten Egg Smell
Rotten Egg Smell
Yeah, i notice that when i get out my max after driving it, i smell a sort of rotten egg smell, also sometimes when im sitting in it. Ive also noticed that ive lost power and my engine runs rough, the gas pedal vibrates a little also on mid throttle revs. got 59,500 miles on it, 00 Auto. Any real noticeble results with getting the spark plugs and fuel filter changed?? Please help. Dealer told me today that everything is fine, they just put in a new drop resistor for transmission but i know how my car is supposed to drive and it shouldn't be that sluggish.
Please help
Please help
What Mastertec said, a common problem with cheaper fuels. Sulfur content a problem where i live and with some of the cheaper aftermarket converters the egg smell is VERY noticeable. OEM converters mucho bucks but tend to do the job much better than aftermarkets if you are thinking of installing one. Sumpin' you have to live with sometimes.........
Originally Posted by NissanMasterTec
A rotten egg smell from the exhaust is usually not a sign the cat is going bad, it is a sign that you are using cheap gas with a high sulfur content.
Originally Posted by Max2000
I had that happen to me.. turn out to be not the CAT
it was the ignition coil problem...
Originally Posted by Gsilk
I had the same problem except my rotors went at same time. Sulfur smell+SES light+bad vibrating when braking=new coil, resurfaced front rotors and -$300.
Does a clogged fuel system produce the same smell because i have let the gas tank run too low a couple of times within the past two months?
try going to pep boys, they sell a product that you add to your gas tank that will help elimiate the rotten egg smell. I had the same problem with a Ford I owned years ago it it did help the problem. YOu only have to do it once.
RWCreative
Sep 21, 2015 11:01 AM
carid
Sep 17, 2015 05:00 AM
