drive belt
Old Dec 20, 2003 | 11:29 AM
binz's Avatar
drive belt
how am i suppose to remove the drive belt on 2000 maxima?
the tensioner wont move when i loosen the tensioner bolt.
thanks,
bin
Old Dec 20, 2003 | 11:32 AM
Zero Deuce SE's Avatar
thanks,
bin
Is there a bolt in the middle of the pulley? That bolt would have to be loosend before the assembly will slide.
Old Dec 20, 2003 | 11:37 AM
binz's Avatar
the problem is the idler pulley wont slide up even after i have loosed that bolt.
are there any other bolts?
thanks,
bin
Old Dec 20, 2003 | 12:20 PM
thanks,
bin
You're welcome. Other than a bolt that holds down the adjusting bracket, I don't know of any other bolts that need to be loosened. Some tensioners have the sliding part attached to the tensioning and loosening bolt where they are joined together. Good luck.
Old Dec 20, 2003 | 03:23 PM
DanL's Avatar
thanks,
bin
Just the locking nut on the front of the pulley. You are using the adjusting
bolt on top to loosen the belt right -- not just trying to manually slide it?
Old Dec 20, 2003 | 05:05 PM
binz's Avatar
after 3 hours of elbow grease and half can of wd40, i was finally able to loosen the bolt holding in the idler pulley. what a pain. installation took no longer than 5 minutes.
thanks for the help guys.
Old Dec 20, 2003 | 05:10 PM
You're welcome. Glad that you were successful.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
markevans999
Oct 25, 2015 08:27 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
