View Poll Results: best intake?
Injen
37
41.57%
Frankencar
29
32.58%
Placeracing
15.73%
others
10.11%
Voters: 89. You may not vote on this poll
Intake. Injen VS Others. Your opinion needed
ah, a similar option:
with all the problems with Frankencar customer service and getting the intake on time, I just order the full Berk Tech intake. similar design, higher grade steel and only $99 shipped with an 8" K&N!!
plus, I ordered it one day and it shipped out the next. should be in my hot hands on monday.....
check the group deal section for more info....
another bit of mind change..... (2 cents worth)
das
das
Originally Posted by Dave Jr
For some people the perception of a cold air intake is a little off. When did it become a cold air intake only if it was in the fender??
It doesn’t have to be in the fender to be a cold air intake. Remember that heat rises. So the pop chargers like Frankencar, Stillen, JWT, whatever will be taking in a good amount of hot air. The Injen sits below the battery away from the motor and away from the radiator. There is a small shield at the bottom of the engine bay to keep water and debris out but does see a very good amount of cold air. I used a temperature scope this past summer to take the temp of a fender located CAI and a front mount CAI (Like the Injen). The front mount intake pipe was much cooler than the Fender located CAI.
The Injen is a CAI and I have one on my max. The sound is godly the performance feels much better mid to high revs. I prefer any CAI over the top mounted pop charger.
Scientific evidence
Originally Posted by 92 SE-R 02 SE
injen is NOT I REPEAT NOT CAI...frankencar owns...dont let the injen haters influence you...a filter CLOSE OR NEAR the rad in N O T C O L D A I R
And your measurement technique was??? Temperature scope owns joo!
Originally Posted by Lumbee1
Scientific evidence
And your measurement technique was??? Temperature scope owns joo!Took the words right out of my mouth
And again since when does a cold air intake HAVE to be in the fender. Is there some kind of Auto Dictionary that I don't know about ?? CAI = Fender mounted Filter system
As stated before I am not bad mouthing anything any intake system over stock is an improvement. It all depends on your needs and wants.
because the general concensus is that the Injen doesnt create much power up top.....
for some reason lv2dmax (the thread starter) is not happy with the gains....
Ohhh I see the only place to get cold are is from the fender. It's so clear to me now.......
warm air off steaming asphalt......
my Franken is a CAI anytime its under 50F Degrees ....its freggin' 20F degrees out right now
Originally Posted by MannyNJ2k2max
you should dyno your car if you swear by the power it makes....that way you can truly say its worth it.....and we can see where in the powerband it helps.....
You are right dyno's tell all at least we think but considering all the HP loss we have seen lately with the TC ECU and the Headers. If the people Dynoing the cars don't know what there doing the numbers are no better proof than an A$$ dyno meter.
So power wise my " opinion " for my car and my situation is the injen feels better in the mid to high end power band. I am not selling the Injen just adding my opinion as was asked by the thread starter.
Once again I will state it. Any intake system over stock is an improvement.
In a way its unclear how on a summer day the Injen could suck in anything but
The fender mounted CAI is completely enclosed from the outside with all the sheilds. When you cut the hole look inside you can't see anything but the funder and sheilds. In a warm summer day this will cause a more severe heat soaking condition. Even when the car is moving again it doesn't see direct air flow because of it being completely enclosed. It's kinda like driving down the road with your windows up. Yes there is air there but your not seeing the air flow.
If you look down in front where the Injen CAI would go you see ground. There will be more elements let in but will also allow more air flow.
If the fender had that much cooler air flow why aren't intercoolers mounted there ???
We are talking a hp here and there- in either case- CAI or not....
Glad you like it Dave!
And in my case I just wanted to clarify that I wasn't stating that Injen made more power than other intakes I was just defending it's status as a true CAI
It was 6 degrees here on the way to work and is now about 15
From this we can conclude:
Frankencar - Hot Air Intake
Place Racing - Cold Air Intake
Injen - Colder Air (fact) Warm Air (opinion) Intake?
Originally Posted by ghostrider17
Where's the best place to buy a PRCAI????
Their website only offers a brochure to be mailed....
gr
gr
and Cattman sells their own version of it
www.cattmanperformance.com
the Franken is a foot and a half away from being a CAI (place racing)
Am I making sense? I think I confused myself
Now this would probably require the cutting of the stock air box but has anyone with a pop charger tried using the stock air scoop that sits at the base of the hood that brings in air from the outside?? I can't remember the actual shape at this point but leaving that connected it would bring in cooler air from outside of the vehicle and allow that to flow towards the filter element that may not be a bad Idea to allow cooler air flow into the engine compartment.
to them. It would make my intake decision alot easier!!
Weapon R sells a ram air kit for their Dragon filters
but I'm not sure how effective it could be-
http://www.weapon-r.com/ramair.html
Originally Posted by spirilis
yeah, 92 SE-R 02 SE just got
by who? i seen the INJENS on the 3.5..sorry not right behind the rad but close enough... wow..injen sure looks pretty...im not about looks.... INJEN IS NOT CAI... PERIOD. CATTMANN AND PRI are. thats why i got frankencar...
I'll ask you again since when does a cold air intake HAVE to be located in the fender to be a cold air intake ?????
If a cold air intake had to be mounted in the fender to be a CAI why name it a CAI then. Why would anyone else use that term CAI if it had to be mounted in the fender ?
It has been proven scientifically that the temperature at the filter of an Injen intake is colder than Place Racing with a temperature scope.
Are cold air intakes not measured by the temperature of the air coming in at the filter? If the temperature of the air at the end of an Injen intake is COOLER than that of the Place Racing, why would you label the Injen WAI and the Place Racing CAI?
I am not sure where or how they measure the air coming in but a cold air intake simply takes in colder air than the stock air box. And it DOSN'T have to be mounted in the fender to do so.
Lumbee this is not directed towards you so please ignore.
I am done debating this simply put a CAI is an intake that takes in a cold air charge and uses it to make raw horse power on a NA vehicle. It simply doesn't matter were the air comes from. Below the car, under the car, in the fender what ever. An intake DOES NOT have to be mounted in the fender to be a cold air intake. PERIOD.
The testing wasn't done with a Place Racing or Injen intake. The fender mount that was tested was an AEM and the front mount was a custom made intake. It was still polished SS just like the injen.
Originally Posted by Shift_VQ
I plan on installing an injen with the apexi filter I have on my frankencar. It'll look better and i think it will perform better too. The Frank is pulling hot air in...I dont see how that can help performance.
is it true that with an injen you lose torque? and why would a frankencar be better than an injen on the highway? Dont both intakes have the same air circulation at highway speeds, especially if you combine an injen intake with an apexi filter???
A cold air intake (Place Racing) doesn't mean it has to take air from the fender, but it's typically the best place to draw the coolest air within close proximity of the throttle body. I can assure you that the air in the fender (which is not near as enclosed as you believe), is the best place to draw the coolest air possible with the hood down, especially on a hot day. The piping of the PR pipe is cool to the touch on a hot day after sitting in traffic. A HAI (Frankencar, Injen) will be scalding hot. I know, I've had all types of setups (no Injen, but I've touched it on a hot day - deadly). The Injen intake sits in absolutely the worst place possible in terms of sucking in air. It sits in close proximity of the cooling fans which PULL OUT heat (ie it sucks hot air out of the bay, not into the bay). ALso, the Injen is damn close to the exhaust manifold and a baking engine block. It doesn't take a rocket scientist to understand why Injen intakes can cause pinging on hot days. DINAN (the BMW tuner) only uses true fender-style CAIs because they want intakes that make proven power under all conditions. They understand that putting the intake in the fender makes the best power. Thier M3/M5/3-series/5-series/7-series/Z-series intakes all pull from the fender. They know that the "POP" and HAI setup make a couple more HP in the upper rpms, but the CAIs give more consistent power across are broader powerband. Remember, power under the curve owns.
Dave
Originally Posted by Dave B
Are you making this up as you go along?
Hmmm...last time I checked turbo Audi's, 300ZX TTs, and 1.8T VW/Audi place their intercoolers in the fenders.
Dave
Dave
And I was lookin to get an Injen too..........
Dave
Dave
Originally Posted by PearlWhtMaX2000
so are u saying that PR CAI is the way to go?? because i too was going to get an injen some time soon
The Injen, while looking quite nice, is situated in the worst possible location. I constantly read about people noting the location of the filter, but people need to also know about the placement of the metal intake pipe which is right next to a large mass of hot metal (block, head, exhaust manifold, intake manifold).
Dave
Dave
Dave
All the things you've said may be true, but according to many people with the Injen and many dyno test there IS an improvement over the stock intake unit. So if its the worst possible location then why does it improve the hp & torque numbers over stock?
the issue at hand is whether its a CAI - the PR intake is truly a CAI because its set up allows
the best intake path- away from the engine.....and where the coolest air
is avalable...
Good point on Dinan...
So how much better is a PR intake than an injen? I am about to sell my frankencar for an injen but use the apexi filter on the injen...but this is making me think I dont want to do that...The only thing turning me off on the PR is the whole drilling idea.
So basically if the injen will not produce noticeable gains compared to the frankencar but PR will...I think Im sold on PR...help
you guys are arguing way too much about the temperature of the incoming air. you're forgetting an important advantage of a CAI over a WAI: the resonance of the airflow created by the long smooth tube. it's a nice continuous airflow (actually has a bit higher psi than normal, but nowhere near forced induction). hard to explain so look it up
