cleaned throttle body, now SES light..HELP
Old Dec 31, 2003 | 11:04 AM
Young04's Avatar
i cleaned my throttle body and replaced a dirty air filter today. the car runs a lot better, i got back a lot of low end that i thought i was missing. only problem is that my SES light turned on when i started the car. i unplugged the battery and will try restarting her in a few hours but in the meantime does anyone know what this may be due to? i went back and made sure i tightened everything etc.
Old Dec 31, 2003 | 11:40 AM
2k3TitaniumSe's Avatar
I never had this problem with my Maximas. So I dunno.
Old Dec 31, 2003 | 12:04 PM
spirilis's Avatar
Unsure... please take it to Autozone for them to pull the code once it comes back on!
Old Dec 31, 2003 | 12:07 PM
2k2kev's Avatar
It's chrome alright...
unplugging the battery doesn't always reset the ECU...
follow these instructions to do that, and if the light stays on/comes back on, then bring it in for diagnosis.
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” (DO NOT actually start the car, just turn the key to "ON") and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10
seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
Old Dec 31, 2003 | 12:08 PM
Larrio's Avatar
The Definitive AE Master
did u plug the MAF back in?
Old Dec 31, 2003 | 12:10 PM
Zero Deuce SE's Avatar
Did you spray any cleaner into the MAF assembly? If so, you may have caused some damage to it. Also, did you get any cleaner into any of the electrical connectors around the throttle body?
PearlWhtMaX2000's Avatar
can someone direct me to a how to on cleaning the throttle body?? and howoften it should be done?
Old Dec 31, 2003 | 12:21 PM
2k2kev's Avatar
some say you can and should clean it (here's how)
http://forums.maxima.org/showthread....+throttle+body
other say NEVER clean it and here's why
you have to decide for yourself.
Old Dec 31, 2003 | 12:43 PM
Young04's Avatar
thanks for the help! this did the trick. went for a drive and the light didn't come back on again either.
pearl white max - you will get differing opinions on whether a throttle body cleaning should be done, but after having done mine at 20K miles, it helped noticeably (most of my miles are city miles and i drive kinda, but not too hard...my car may see 5500rpm+ once a week on average)
i followed the directions on the link above and it's not too hard. i'm not very mechanically inclined and wasn't too bad.
Old Dec 31, 2003 | 12:56 PM
ok thanx alot
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
97_GXE
Sep 15, 2015 06:47 AM
followthadollar
Sep 13, 2015 09:55 AM
Maxboy23
Sep 9, 2015 10:37 AM
