UR UDP going from 2k to 2k2
Old Jan 14, 2004 | 01:55 PM
Fezzik's Avatar
Got a question> i removed my UR UDP from my 2000 maxima and want to put it on my 2k2, but it has the timing ring on it. Has anyone removed this and can give me a hint on what to do. I dont want to screw this thing up.
Old Jan 14, 2004 | 02:36 PM
Y2KSESteve's Avatar
Different part numbers. I wouldn't try installing it.
Old Jan 14, 2004 | 02:40 PM
MannyNJ2k2max's Avatar
quansung added a 2k pulley to his 2k2
Old Jan 14, 2004 | 02:48 PM
Y2KSESteve's Avatar
I guess its' possible then.
Old Jan 14, 2004 | 02:55 PM
he also has a failed VIS(not sure if relative...)
Old Jan 14, 2004 | 03:11 PM
bsetiawan's Avatar
Try to heat it up in the oven a little. I guess the hex bolt is glued onto it. Otherwise you may want to contact UR directly and ask them how to remove it. The only difference between the VQ30DE and VQ35DE is that timing ring. It will fit fine once you remove it.
TallTom
57
Oct 14, 2025 05:16 PM
Dave B
May 29, 2001 11:07 AM
y2kse
Feb 25, 2001 08:47 PM
Andrew91SE
Nov 26, 2000 03:05 AM
