Problem With psg side window.
Old Jan 19, 2004 | 08:32 PM
PearlWhtMaX2000's Avatar
my psgr side window is acting funny lately. when you put the window down, it wont go back up if the Psngr tries to make it go up. but when i do it from the driver side controls it goes up. is the switch on the passenger side broken?? i dont think it is because it goes down just not up.
i know this sounds confusing but if anyone knows what this might be, any info would be great
thanx
Old Jan 19, 2004 | 08:35 PM
scopium
its most likely the passenger switch... if u have warranty on the car then u shoudl just take it to the dealer...
Old Jan 19, 2004 | 08:41 PM
nop no warrenty. but what confusses me is that it goes down, but it takes like 7-10 times to push the button up untill it works
Old Jan 19, 2004 | 10:03 PM
housecor's Avatar
There are likely separate contacts to sense the up and down motion of the power window button. It sounds like your "up" contact is either going bad or somehow loose.
I'd open up the door panel and give it a look. You shouldn't have to remove the whole panel. Instuctions: http://carstereohelp.com/stereoremovalNisMax3FSpk.htm
If the switch is bad, i'd hunt down a replacement from a junk yard. Cheap.
Old Jan 20, 2004 | 08:36 AM
mistadee77's Avatar
I had the same issue a few months back just go to the dealer and purchase the part I thik it cost me like $21 bucks you can install it yourself, take about 5 minutes....
Old Jan 20, 2004 | 10:31 AM
ok ill check it out thanks guys
Old Jan 20, 2004 | 03:50 PM
Nathan's Avatar
I have a problem with one of my rear passenger doors too. Except its the lock instead of the window. The power door locks dont work at all on one of the rear passenger doors. Could there be a blown fuse? All the other door locks work except for this one door. Anyone have the same problem?
Old Jan 20, 2004 | 07:07 PM
02VQ35's Avatar
Mine did this too and it wasn't a switch but a dying regulator. Chris
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
