2k2-3 owners please read! Recall info...
Old Jan 24, 2004 | 07:13 AM
MannyNJ2k2max's Avatar
As all of you know there is a recal for the Crank Engine sensor- I just got my vehicle back from the Service department @ Flemington Nissan (great serviceSo I asked Steve (service manager) for a few answers- hope this is helpfull....
* this recall involves replacing three (not one) sensors in the timing system that have been updated
* recall was also extended across other Nissan vehicles (Murano, Alty, he mentioned)
* Nissan owners where experiencing : 1) Car wouldn't start, 2) Car would shut
down (limp mode) during driving periods
* I asked him also about MAF problems and he responded that there have been many more problems due to these sensors than MAF problems (very few)
* I also inquired on what I should do about the brake problem (jutter) and he told me to bring back the car before 36K and the rotors are fully replaceable under 36k warranty!
I also got the Datadot/brackets done- stickers aren't that bad!
Old Jan 24, 2004 | 07:25 AM
Oh I forgot- the misconception that some org members have (that have had post recall power loss/problems) had something to do with the ECU-
he mentioned the ECU "does not" get flashed/reprogrammed for this procedure!
Old Jan 24, 2004 | 07:32 AM
MaxSE03's Avatar
I know that they have to change the engine crank position and cam position sensors, but what is the third one?
Old Jan 24, 2004 | 07:39 AM
IgS's Avatar
IgS
sweet thx for info, ill be making an appointment today
jw, how long did it take, so i know in advance
thanks
Old Jan 24, 2004 | 08:16 AM
03maximan's Avatar
It only took a little over a hour for mine to get done, but I had to wait ten days for a appointment.
At first it seemed to have less power , but now I think it's ok.
Old Jan 24, 2004 | 08:17 AM
2k3TitaniumSe's Avatar
the crank sensor makes the engine have a weird noise when started right?
Old Jan 24, 2004 | 08:24 AM
hotrod37's Avatar
no the crank angle sensor has nothing to do with that noise.
Old Jan 24, 2004 | 08:25 AM
Y2K2Driver's Avatar
1x Crank
2x Cam
Old Jan 24, 2004 | 08:35 AM
03maximan's Avatar
Anyone with an 02 or 03 have the "lack of power " tsb done (this is the one where they re-flash your ECM).
I asked about it when I had mine in and he said it didn't apply to my car but said he would check to make sure, nothing was noted on service receipt, just engine sensor kit.
Old Jan 24, 2004 | 09:05 AM
I thought the lack of power TSB was for 2k-2k1's......Although there have been some org members that have had problems with accelerator pedal sensor
Old Jan 24, 2004 | 09:06 AM
bigdo26's Avatar
I also had the recall done, bout 3 weeks ago. It took roughly 1.5 hours and there were no problems. Car runs same after as it did before. Course I had to inform the Nissan dealership that there even was a recall out... but thats ok, I'm well informed
Old Jan 24, 2004 | 09:22 AM
JustTry's Avatar
Originally Posted by Y2K2Driver
1x Crank
2x Cam
3x Timing.
Old Jan 24, 2004 | 09:36 AM
dracip's Avatar
Do you have pics of the brackets ? HID theft is not a problem here, but I plan to travel on the East Coast this summer.
Denis
Old Jan 24, 2004 | 09:41 AM
03maximan's Avatar
http://maxima.theowensfamily.com/tsb/--------------this is where i found it. Also check out this thread.http://forums.maxima.org/showthread....hreadid=198305
Old Jan 24, 2004 | 10:17 AM
TheyCallMeSteel
I just had this done to my I35 when it was in for service. They didnt even tell me, just did it, how nice.
Old Jan 24, 2004 | 10:24 AM
IgS's Avatar
IgS
damn you, you "i got serviced by infinity" guys
haha just kidding, but yeah i wish nissan service was that nice...
Old Jan 24, 2004 | 11:15 AM
Quidproquo's Avatar
Datadots are your friend....
Old Jan 24, 2004 | 01:12 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
NTB03-023 is for 2002-2003 Nissan Maximas and Altimas with the 3.5L VQ35DE engine...
That's the lack of power/hesitation TSB that is being referred to.
Old Jan 24, 2004 | 02:11 PM
Mass_Media's Avatar
Mass_Media™
So the symptoms of the recall are car won't start or turns off during driving mine has done that any other symptoms?? Should I take mine in to be safe?
Old Jan 24, 2004 | 02:26 PM
Ferbs02SMMax's Avatar
You and 2k3TitaniumSe should go to Woodfield Nissan in Hoffman Estates for this and and the transverse links tsb. I had those two and the fogged up headlight tsb service, and also had my brake judder/pulse problem remedied, they resurfaced the rotors free of charge, under warranty.
See my experience below at
http://forums.maxima.org/showthread.php?t=280482
Old Jan 24, 2004 | 02:31 PM
Mass_Media's Avatar
Mass_Media™
Even if my car isn't under warrenty??
Old Jan 24, 2004 | 02:34 PM
Zero Deuce SE's Avatar
If your VIN falls within the range of JN1DA*1**2T 000002 - 454681, you are covered under the engine sensor recall.
Old Jan 24, 2004 | 04:13 PM
KLOOGY's Avatar
L33t BMW Drivah
I had the cam and crank replaced last week. Now the intake solenoid is bad. They told me , that Nissan was sold a bad batch of sensors, which they used on all Nissans.....that is the reason for the recall. The symptoms Manny listed are correct. My car went into limp mode twice, and finally shut down, and wouldnt start.
220k+ A32
18
Sep 22, 2015 11:39 AM
flu2000
Sep 8, 2015 02:23 PM
crazyespn
Sep 3, 2015 01:30 PM
