Cat installation
Old Jan 24, 2004 | 04:57 PM
Rich96's Avatar
Cat installation
Is there a write up anywhere?
Old Jan 24, 2004 | 05:21 PM
BEEI30's Avatar
http://www.max-world.org/writeups/5t...tos/rtcat.html
now i need to know how to install y-pipe?
Old Jan 24, 2004 | 09:43 PM
JayMax2000's Avatar
It's not too hard if you can get those bolts off. I had to use a torch.
Old Jan 24, 2004 | 11:51 PM
[maxi-overdose]'s Avatar
cat:
-jack up the car
-remove heat shield on the cat
-remove 4 14mm nuts that hold the cat - use some WD40 if you got stuck with them
-put a new one on
-apply antseize on the bolts
-torque spec 38 -48 lb/ft. more if you use antiseize.
-put heat shield back.
-start the car and check for exhaust leak.
ypipe
-jack-up the car
-remove the two O2 sensors on the stock ypipe with O2 sensor socket or a 22mm wrench.
-dont drop your O2 sensor
-remove all the nuts and bolts that hold the stock pipe. you will need 12" extension for the bolts on the rear exhast manifold. If you got stuck, WD40 is your friend.
-take off the stock ypipe and be careful with the O2 sensors
-you will also need to remove the black metal plate that holds the O2 sensor wire.
-remove exhaust gasket if they are still on the manifolds.
-apply anti-sezie on ALL bolts.
-install ypipe and use NEW exhuast gasket (this is a bish if you have cali spec pipes)
-put all the nuts and bolts back
-torque them down to 31 - 38 lb/ft. more if you use antiseize.
-put your O2 sensors back - use antiseize on the threads too. torque sepc 33 - 40 lb/ft.
-start the car and check for exhaust leak or engine code.
-test drive - zoom zoom
Old Jan 25, 2004 | 07:21 AM
BEEI30's Avatar
Cool thanks....just the rusted bolts giving me trouble now.
Old Jan 25, 2004 | 11:07 AM
no problem.
spray some WD40 and let it soak for 10 - 15 minutes.
MaxLife17
Jun 27, 2019 01:37 PM
carid
Sep 9, 2015 05:06 AM
Maxboy23
Sep 4, 2015 06:04 PM
Johnny9595
Sep 3, 2015 05:18 AM
Justin Kroll
Sep 2, 2015 11:06 AM
