Bulbs for reverse lights like Y2Kev's
retired moderator
I know he has the Gigalux BW701's, but I cannot find ANYPLACE that sells them (and I have no connections in Japan)...
Anyone know of any other replacement reverse light bulbs that will look white at night but have that nice blue reflection in the day? I think the stock bulbsare 13W and the gigalux's are 18W.....Does PIAA or anyone else make a bulb that is similar?
retired moderator
Originally Posted by PearlWhtMaX2000
i gotr the autozone cheepos and they are what u are looking for also. 3 buks
retired moderator
The stock bulbs are either 912 or 921 (13W) - 912 and 921 are interchangeable. I don't know if those codes are the same for the other aftermarket bulbs.
btw, DrVolkl, it appears your cardomain site is not working (or at least the link here to it...)
just ordered mine for $11.49 at http://www.ttstuff.com/Merchant2/mer...ode=PIAA-19224
can't beat that.
can't beat that.
Originally Posted by DrVolkl
Hey, what's the bulb serial # on that? I don't feel like pulling the bulbs out to check and I'd like to order a pair myself...(another brand)
The size for reverse signal in our tail light is W2 as Dave has said and PIAA seems to be the best choice. I don't have others but I have the PIAA and I can vouch it looks good, just like irish wanted. Very white light output at night, slight hint of blue in the day.
~limsandy
Originally Posted by Wolfgraen
http://www.optauto.com/webstore/prod...t=470&last=470
these guys have the same bulbs for $9.95 for a pair
Originally Posted by irish44j
I checked 2 local autozones....no luck at either place.....you guys in the NE must have better selection!!!
i just found out that have them at TWEETER
5857 LEESBURG PIKE SUITE B
BAILEYS CROSSING, VA 22441
(703) 845-8707
http://www.tweeter.com/searchHandler...PIAA&y=15&x=27
Originally Posted by soonerfan
i want bulbs that are ACTUALLY white for all my interior. where can i find the sizes? and is PIAA the best way to go?
map
dome
ones on inside of door
map
dome
Dome Light = T-6D-XTRW-T
Inside Door Light = 168-XW-T (should be..not sure tho)
Map Light = should also be the same as inside door light if not then the same as the dome light...hope it helps.
Originally Posted by Y2K1JKSE
PIAAs are the way to go..whitest and brightest..i have a PIAA dome light and PIAA LED trunk light
Inside door light you can use either 168 or 194. However, the map light is a different bulb than both the dome light and courtesy light.
dude,
(703) 845-8707
(703) 845-8707
http://www.cardomain.com/member_page...224200&page=13
I'll put Polarg M6s in the reverse lights as they appear to be brighter.
I've got some pictures on my page too.
The Frye
09-02-2021 11:03 AM
fastcarny
10-06-2015 10:42 AM
Maxima30
09-07-2015 06:13 PM
