HyperGrounding points.
Old Feb 25, 2004 | 10:29 PM
thomasd cook's Avatar
How many hyper ground points are there? I'm going to make my own HyperGround kit and am getting 20 ft of wire. Does that sound like it's enough wire? Search isn't working.
Old Feb 25, 2004 | 11:21 PM
maximilion's Avatar
20 feet sounds more than enough. I think there are about 5 grounding points - no more than 6.
Old Feb 25, 2004 | 11:43 PM
Anyone know exactly where those 5 grounding points are at?
Old Feb 26, 2004 | 02:12 AM
redstradic's Avatar
i used these grounding points:
Old Feb 26, 2004 | 02:14 AM
redstradic's Avatar
i think i am going to get one more and have it go to my transmission.
Old Feb 26, 2004 | 04:28 AM
2k2MerlotSE's Avatar
JUVIN's ride
sorry for the newbie ????.
I know what a ground is, but what is the hyper ground all about?
Old Feb 26, 2004 | 05:59 AM
spirilis's Avatar
hyper ground is an invented term referring to the reinforcement of ground points in a vehicle. Basically, instead of just connecting things to ground points and assuming it's perfectly grounded, you add cables between the ground points to ensure the ground points can conduct between each other in an optimal manner, rather than assuming that the engine block/chassis/etc. conducts well enough. For best results, this hyperground "network" should connect to the alternator ground AND battery ground, since they are both power sources. Ultimately, for any power-drawing device, the circuit will require proper conduction from the device's ground to the power source's ground, so including the power sources in the hyperground network is the ideal design.
Old Feb 26, 2004 | 06:09 AM
panda_1's Avatar
i was alos planning on creating my own grounding kit. my question is what are the point i.e battery, tranny, motor etc etc etc.
Old Feb 26, 2004 | 06:15 AM
JUVIN's ride
so the cableing is ran from ground point to ground point.
I thought it meant running cables from each ground point to a main area, like a ground bar or something.
Thanks for the info, help me understand what everyone is talking about.
Old Feb 26, 2004 | 06:29 AM
spirilis's Avatar
It could be that too. Either way, it's the same effect.
Old Feb 26, 2004 | 05:15 PM
Also, when I put the ring terminals on the ends should I crimp them on or solder them on?
Old Feb 26, 2004 | 07:02 PM
maximilion's Avatar
soldering is always better, but since you'll probably be using 4 gauge wire or something, crimping might be a more realistic alternative.
Old Mar 3, 2004 | 01:33 AM
panda_1's Avatar
hello...isnt anyone going to help me out by telling me what the grounding points are?
Old Mar 3, 2004 | 07:12 AM
Matt93SE's Avatar
STFU n00b!
try opening up your service manual doing do a little research on your own... That's what the rest of us have done.
Old Mar 4, 2004 | 10:55 PM
VMaximus02's Avatar
I noticed that you listed the grounding kits for the 5th gen for sale. Does the kit works on 5.5 gen Max? If so, do you provide instruction for the installation w/the purchase? I am seriously considering this electrical enhancement.
irish44j
78
Jul 8, 2004 02:16 PM
cato
173
Dec 2, 2003 04:08 AM
97MaxGurl
Nov 5, 2003 11:13 AM
JMAX95
Jan 2, 2003 02:08 PM
boo
20
Dec 26, 2002 07:15 PM
