Foglamp Replacement
Old Mar 14, 2001 | 06:21 PM
killrwheels's Avatar
I have taken both panels off under car and cannot figure out how to replace bulbs. I can disconnect electrical contact and remove small 10mm screw, but assembly will not slide out. Any help would be appreciated......
Old Mar 14, 2001 | 06:35 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Tap the lamp from the inside (hitting outwards) with a screwdriver, hammer, mallet, or whatever you can. Just make sure you don't tap too hard... Push outwards and catch/stop the lamp.
Old Mar 14, 2001 | 06:41 PM
At the top of the foglamp assembly there are two grey pins held in place with white fasteners, should these be pulled first, or no relation to installation. Car is a 2001 @0th Anniversary Model and I found it easy to replace headlamps with PIAA's but foglamps are a pain......
I would also like to know more about the transmission stall between 1st and 2nd. I thought it may be unique to this model and have not questioned dealer.....
Old Mar 14, 2001 | 06:47 PM
Y2KevSE's Avatar
Check out "cmon Punkdork... Send me the new tranny tsb through my email... " for a copy of the slippage.
Check out pics 8 and 9: http://wwwcsif.cs.ucdavis.edu/~chin/...iles/cai2.html
Does that look like your assembly? If yes, just push it outwards.
Old Mar 14, 2001 | 06:49 PM
UMD_MaxSE's Avatar
Got Bent?
If your traany is slipping, take it to the dealer and try and get them to work on fixing it. It may turn in to a bigger problem later on which may involve replacing the entire tranny....be sure to get the TSB....
Old Mar 14, 2001 | 07:19 PM
irvine78's Avatar
wellz...u just gonna have to bang it out now..
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
cruce91
Sep 20, 2015 10:23 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
