2001 SE front wheel Vibration
Old Mar 7, 2004 | 08:10 PM
redbull's Avatar
I'm having some weird vibration in the front driver wheel over 45mph... it feels like it shudders on and off...If I had to describe it..it feels like the wheel is bouncing really fast then stops or moving side to side really fast anyone have any ideas???? It only does it on the driver side front wheels. I swapped the wheel and tire to the e back and does the same thing. I thought first maybe wheel out of balance or a tire with a bump on it or something. THe car has 47K miles. Thanks for any help.
Old Mar 7, 2004 | 09:23 PM
FusionAcid's Avatar
possible suspension issue...get it checked by a mechanic. You don't want your tire popping out or anyhing
Old Mar 7, 2004 | 09:25 PM
Maxpat82's Avatar
the wheel does the same thing or the front left corner??(when you swapped to the rear)
Old Mar 8, 2004 | 09:15 AM
redbull's Avatar
THe left corner does the same....
Old Mar 8, 2004 | 09:31 AM
Maxpat82's Avatar
then, it's like FusionAcid said: Suspension issue!!
bad Shock, maybe a ball joint, tie-rod end too!!
Have it check by a mechanic!!
Old Mar 8, 2004 | 09:57 AM
SoonerFan's Avatar
Cletus
not balanced?
warped rotor?
Old Mar 8, 2004 | 10:27 AM
Maxpat82's Avatar
Wraped rotor??
Correct me if I'm wronf but:
Doesn't this only vibrate when applying brake, not when you are cruising at 45Mph?
Old Mar 8, 2004 | 10:52 AM
SoonerFan's Avatar
Cletus
Wraped rotor??
if its really bad, it will do it all the time. it spins crooked which causes the vibration.
Old Mar 8, 2004 | 11:27 AM
redbull's Avatar
I already replaced the break rotors because they were wrapped. The shudder occurs on and off its not constant. ANd it only occurs when driving and not while breaking.
boomerbrian
Nov 8, 2015 05:10 PM
Starrider
Sep 17, 2015 07:26 AM
seesole
Aug 26, 2015 11:22 AM
twotonezed
Aug 16, 2015 11:41 AM
BassAddictJ
Aug 4, 2015 11:38 AM
