How to change belts
Old Apr 6, 2004 | 12:59 PM
machplane's Avatar
How to change belts
Hey, fellas, can somebody give me advice on how to changes the belts on my 2k, what kind of tools i will need, the precedures, and what to look out for
Appreicated
Old Apr 6, 2004 | 04:25 PM
ZIPPIN's Avatar
Mauja He Mauja
Appreicated
why do you want to change them? are they cracked????
Old Apr 6, 2004 | 04:35 PM
machplane's Avatar
yep, it's starting to crack
Old Apr 6, 2004 | 05:00 PM
theMax's Avatar
Good Luck,
PM me your email for a pic of the drivebelts.
You'll need a few extensions and universal joints, as well as sockets. Then you'll need a ruler to measure tension.
First you need to jack up the passanger wheel and remove it. Put that end of the car under a jackstand.
Remove the plastic cover in the wheel well.
For the larger belt you can reach this with a ratched and extension. Loosten the lock and lower the pully.
Then for the hard part. For the power steering belt loosten the nut facing the fender, then you can get to the vertical bolt to lower the pulley. Before you lower the pully you must move the power steering pump by working that bolt as well.
There are some how-tos out there but they are under the UDP installation, just don't take the pulley off!
-\studman's 2002 Nissan Maxima SE - UDP Installation.htm has a good page but I couldnt find the entire link
Once you have enough slack to remove the belts, put new belts on and tighten them up. Do not overtighten. Adjust until you have the correct deflection. (in the pic I can send)
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
RWCreative
Sep 21, 2015 11:01 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
