Replacing front speaker
Old Apr 10, 2004 | 01:10 PM
ldn323's Avatar
My wife has a 2001 GXE. The right front speaker is blown. I just happen to have a pair of new 6.5" dual-cone speakers sitting around the house so I am going to replace the front OEM speakers with these. However, upon removing the door panel, I realized that the OEM speakers use specialized plugs which of course won't fit my conventional speaker terminals.
Has anyone dealt with this before? I'd appreciate any advice you can give.
Thanks.
Old Apr 10, 2004 | 02:24 PM
DAP's Avatar
DAP
I think Circuit City sells those connectors. I know Crutchfield does but you would have to wait for those to come in the mail.
You can always cut the stock connectors off and crimp on the correct ones too.
Old Apr 10, 2004 | 02:33 PM
NYC TAR's Avatar
I would just cut the OE harmess and reconected cted it ( Solder it). Same with the speaker braket.
http://www.sears.com/sr/javasr/searc...et=Subcategory
Old Apr 10, 2004 | 06:38 PM
young1976's Avatar
Is the car still under the factory warrenty?
Old Apr 10, 2004 | 07:26 PM
ldn323's Avatar
Unfortunately, no. It currently has 43K+ miles.
Old Apr 10, 2004 | 07:49 PM
2MuchMAX4U's Avatar
Did you replace the speaker yet? If not then here's what you do: remove the speaker via 3 screws, un clip the harness. You can use the old speaker as a bracket and use keep the harness. Just cut out the speaker, remove the magnet and cut the plastic supports that hold the magnet.
Clean up any mess left and screw the new speaker into your "custom bracket" and solder the speaker to the leads on the back of the bracket.
Robert
Old Apr 10, 2004 | 08:01 PM
scopium
why does nissan make everything so difficult and time consuming to change...
Old Apr 10, 2004 | 09:14 PM
kclmax2k1's Avatar
One option is to buy the speaker bracket (for bose speaker) from dealer. That way will save you some trouble and is very easy to install
MikesChevelle
Nov 23, 2024 11:17 AM
jskirwin
Jun 8, 2016 08:49 AM
vingodine
45
May 21, 2016 12:46 PM
Samedi
Aug 12, 2015 01:54 AM
Mcnabb34
Aug 11, 2015 08:45 PM
