Need easy way to re-set "service engine light"
Old Apr 12, 2004 | 10:29 AM
mike_747's Avatar
While replacing the fuel filter on my Max. during startup, due to temperary
low fuel pressure, the "service engine soon" light came on.
Is there a simple way to turn this off and re-set it without going to a
mechanic?
thanks
Old Apr 12, 2004 | 12:12 PM
ahaling's Avatar
These procedures from Technosquare indicate they are for the 350Z, but works also on Maxima.
http://www.technosquareinc.com/350reset.htm
Old Apr 12, 2004 | 12:22 PM
BLaZin 2k MaX's Avatar
Just disconnect your battery for a couple of minutes then reconnect, should be off.
Old Apr 12, 2004 | 01:21 PM
GLE2000's Avatar
Drive it for 3 days or so. After several successfull driving cycles if the PCM detects no more faults it will remove the code from memory automatically and turn the SES light off.
Old Apr 12, 2004 | 04:52 PM
Dee Dibease's Avatar
mechanic?
thanks
I disconnected the battery overnight and in the morning and when I woke and reconnected the battery the SES light was gone. But it came back the next day. (O2 sensor) Don't let that happen to you
Old Apr 12, 2004 | 05:39 PM
gsumax's Avatar
your light comes back on cause there is probably something actually wrong with your car
Old Apr 13, 2004 | 10:41 PM
ummm yeah like i said its the o2 sensor
Old Apr 14, 2004 | 06:05 AM
gsumax's Avatar
so did you think your car would be fixed if you just reset it??
Old Apr 14, 2004 | 07:42 AM
swapmeetlouie's Avatar
You can also go to an auto parts store like AutoZone or PepBoys etc and use their OBDII scanner to read the code and then clear it. Just hook it up to the plug under the steering column. Fast, free, and easy... I have been using it to help me fight my coil problem...
seesole
Sep 14, 2015 12:38 PM
Steven Orozco
Sep 12, 2015 10:41 PM
ballerchris510
Sep 11, 2015 05:29 PM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
jfl330
Sep 4, 2015 01:44 PM
