Tokico Illumina owners step in
Old Apr 30, 2004 | 07:56 PM
MacAlert's Avatar
I had the Illuminas installed with Maxspeeds for about 1000 miles now. I was driving around today and heard a weird come from the rear. I never heard this before so it caught my attention. When the strut compresses, I hear a squeeking noise from the right rear strut. I also hear something knocking or rattling whenever I hit bumps (no its not the Blose sub rattle cause that crap ain't working). Has anyone else had this problem? If you do/did, please post here so I can contact Tokico and tell them about the problems. TIA.
Old Apr 30, 2004 | 08:20 PM
theMax's Avatar
When I installed my maxspeeds I had a similar squeak/ I first checked to make sure the strut bolts were tight and that helped a little. The rest of the squeaking went away over the next few weeks. I guess it was the springs breaking in?
Did you install the rubber spring covers at the top of the spring?
Old Apr 30, 2004 | 08:23 PM
MacAlert's Avatar
What spring covers at the top? I know there were spring isolators installed at the bottom of the strut. I think I'm going to call the mechanic who installed the struts and see what he says.
Old Apr 30, 2004 | 10:24 PM
housecor's Avatar
My guess is the spring is rubbing against the bottom of the perch. If the mechanic didn't use any kind of adhesive to stick the spring isolator to the spring, the isolator can slide and expose the end of the spring. This can lead to metal on metal contact with the end of the spring and the perch. Easy fix. Remove the strut. Compress the spring. Reseat spring and isolator. Reinstall. Instructions on my page.
Old Apr 30, 2004 | 11:11 PM
TEEdotMAX's Avatar
not sure about the squeeking but as far as the rattling goes... remember that your springs will settle down after a little while and you may need to re-tighten the top locking nut
Old May 1, 2004 | 01:38 AM
1BADMAX's Avatar
Yeah mine made a squeaking sound too on the right rear. It took them about a month to stop.
Old May 1, 2004 | 05:49 AM
Ammi's Avatar
350 Detroit Muscle
Is it more of a poping sound?
Old May 1, 2004 | 08:27 AM
MacAlert's Avatar
Not a popping. It makes the sound whenever I hit a bump and it sounds like something is hitting somewhere.
Old May 1, 2004 | 10:15 AM
Ammi's Avatar
350 Detroit Muscle
It's not a high pitch squeaky sound right?
Old May 1, 2004 | 11:44 AM
MacAlert's Avatar
Not high pitch, its really faint but I can hear it when pushing the backend down from outside.
Old May 1, 2004 | 08:02 PM
Ammi's Avatar
350 Detroit Muscle
I get sound from rear when I go over bump sometimes. I'm thinking it's the bumpstop.
Old May 2, 2004 | 05:40 AM
MacAlert's Avatar
Well, I just noticed that the rear spring isolator is coming off the spring. Taking it to mechanics tomorrow. Thanks guys.
gigabyte
Jan 6, 2017 06:05 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
