What happends if I put more than 4.25 quarts in?
Old May 13, 2004 | 07:15 PM
SE01's Avatar
The manual says to put 4.25 quarts of oil in on the oil change. I put exactly 4.25 in. Should I put a little more in, like 4.5 or so quarts? Would this affect the engine in any way? Should I keep putting 4.25 quarts in or less or more?
Old May 13, 2004 | 07:17 PM
Ammi's Avatar
350 Detroit Muscle
adding extra .25 quarts is not going to hurt. If you add few extra quarts, that's different story.
jeepik's Avatar
i put 5 quartz in
Old May 13, 2004 | 07:19 PM
SE01's Avatar
Would it be better to put 4.5 in rather than 4.25?
Old May 13, 2004 | 07:40 PM
irish44j's Avatar
retired moderator
You car will explode. So will your house. Or, nothing will happen at all.
Seriously though, it won't hurt anything.
Old May 13, 2004 | 07:49 PM
Tommy Boy's Avatar
Not a good idea to over fill. If too much oil is in the pan the crank can whip or aerate the oil into a foam, which is no good. Granted, a 1/4 to 1/2 quart probably won't put you into this situation, but don't go more than that.
Old May 13, 2004 | 09:54 PM
limsandy's Avatar
You run the risk of voiding your waranty...... that's if you took your car to a Nissan dealer. I've been told by my local dealer so.
~limsandy
Old May 13, 2004 | 10:02 PM
maximo-SE's Avatar
4.25 is jiffylubes standard... just found out they do take off about 15 bucks if you bring in ur own oil.... not that bad i guess if you one of those people who dont have time.
Old May 13, 2004 | 11:06 PM
† ErV †
The biggest danger with overfilling is creatingmore pressure and damaging seals. In rare cases, you can literally bog your engine down, but that means really just sticking in a hose and letting it pour. Thought it has been done.
4.2-4.5 is just fine. 5.0 is too much though it shouldn't kill it.
Old May 14, 2004 | 03:24 AM
MrGone's Avatar
can lead to higher oil pressures and premature bearing wear.
Old May 14, 2004 | 09:34 AM
Larrio's Avatar
The Definitive AE Master
too much oil will cause a drop in oil pressure when something happens to the oil in the engine (forgot the term for it)
i also imagine you'll get alot more excess oil particles traveling back into your intake tract
Old May 14, 2004 | 09:46 AM
jonbth's Avatar
I'd put 4 quarts in and check the oil level and add what you need. I've found 4.25 quarts puts the level a little bit over the high mark on the dipstick.
Old May 14, 2004 | 01:00 PM
Galo's Avatar
Maxima Pilot
Aeration. Y'ur a good man, Larrio...
Old May 14, 2004 | 03:51 PM
Ammi's Avatar
350 Detroit Muscle
Don't forget that too much oil can cause leaks as the extra oil is forced past seals and gaskets.
James92SE
142
Jan 2, 2024 09:23 AM
foodmanry
Sep 24, 2015 12:02 PM
220k+ A32
Sep 23, 2015 03:38 PM
pjgreek
Sep 9, 2015 09:30 PM
Justin Kroll
Sep 2, 2015 11:06 AM
