How are you cleaning your MAF?
I read 2-3 posts were people were haveing similar engine problems to what I am going thru. The recommendations were to clean the MAF. This is my question: What do you clean it with? What do you clean, the sensor, the housing, what? Please let me know. you guys rock!
Originally Posted by sloppymax
unplug the connector on the maf. unscrew the 2 security torx bit and pull the entire black piece out. you will see a thin wire in the middle of the hole at the bottom. i used electrical parts cleaner since it will do the job and wont harm the plastic surrounding the wire. i gave it 2-3 good sprays and reinstalled. acceleration seemed less jerky but it still pulled the same. that was on the standard maf but i replaced it with the updated one.
and what was the new feeling after you changed the MAF. Is it worth it changing it. I have an 01?
Were do you get an updated MAF? What is different from that one to the standard that came in the car? How much $$$ was it?
Were can I get the Torx for the security bolt?
Do what sloppymax said. I use brake cleaner for both my max and S10 Crew Cab
and air dry it with an air compressor. This works great and it never gave me
any problems. Good luck
Mike
Mike
Originally Posted by chinaonnitrous1
god you guys are playing with death. hahaha
BLACK2000 just go to Autozone and pick up some CRC electrical parts cleaner, and when you take out your MAF just spray it down all around, this CRC stuff is made for sensititive electronics and dries completely almost immediately upon contact. It worked great for me (mine was pretty dirty after 100k miles)
Good luck
Originally Posted by maximo-SE
so.... we do this on regular basis?... just want to know..
Nissan will tell u is not a serviceable part cause they want your $200 buxs to replace it.
Originally Posted by Kiosk
LOL.....so you are spraying your car with NOS and talking about playin with death??? LMAO!!!
Good luck
Good luck
Ha, shut the ***** up. I probably know more about nissan MAF's and why they fail than you ever will. No I dont spray nitrous on my 2002 maxima, please check your self. Ive been through more than 4 MAF's in different models, modified them and everything.
Actually, on that note... why do they fail?
TallTom
50
07-08-2022 09:54 AM
04-16-2020 05:15 AM
fx4five
10-01-2015 04:58 AM
