misfiring coil
Old Jul 8, 2004 | 04:28 AM
mclee45's Avatar
misfiring coil
will taking off an ignition coil make the car pull a misfire code? If not, how do you make the car produce a misfire code?
Old Jul 8, 2004 | 05:12 AM
ZIPPIN's Avatar
Mauja He Mauja
why would you want to pull one? is it misfiring?
Old Jul 8, 2004 | 08:41 AM
mclee45's Avatar
coils are bad, but not bad enough to pull the codes so dealership would not replace them. So I'm trying to get the ecu to pull a misfiring code (IE bad coil) so the consult II can pull it and show the dealership that the coils are bad. I get some knock and hesitation when driving.
Old Jul 8, 2004 | 08:53 AM
ZIPPIN's Avatar
Mauja He Mauja
i am not sure if unplugging it will do it for good. it may do it only when unplugged...but if you planning on unplugging it and taking it to the dealer, they will find out. what do the say about the hesitation?? the knocking could be due to gas. try amoco 93. i did that and the pinging and knocking went away. the hesitation though went after changing the coils and MAF...
Old Jul 8, 2004 | 09:40 AM
mclee45's Avatar
well, once the code is up, the ecu stores it. The consult II will then be able to pull that code at least to show that there was a misfire. i've only used premium 93 oct gas. so its not the gas causing the knocking.
Old Jul 8, 2004 | 03:01 PM
FusionAcid's Avatar
ya if i were u..under warranty? take 1 coil out ...it might take longer than you expect to get the code..not sure if driving with 5 cylinders is safe for engine also...
once code is in...put the coil back..and stand behind the dood who's scanning the ecu and read what the error says and tell them to fix ur car NOW!
Nissan is pulling a scam with their faulty ignition coils....nissan should suffer for their carelessness and lack of consideration to their customers. Anyone know what happened with that petition?
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
howardis
Dec 11, 2019 06:10 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
