6 spd lockout problem
Old Jul 21, 2004 | 03:18 AM
Y2K2Driver's Avatar
The other day I was trying to double clutch into 2nd faster than I normally do, so to do so, I moved the shifter to the left in anticipation for pulling it straight down into 2nd quickly once I had gotten the revs up. Well, for whatever reason, my subconcious decided otherwise. I ended up revving it and then pulling into 2nd w/o the clutch pushed in. To my surprise, the revs dropped a little and then the shifter just popped into 2nd gear. I didn't hear any grinding and for what its worth, the gear change was perfectly smooth. However, I'm paranoid about the synchronizers and confused why the gear lockout didn't prevent this from happening. Can anyone say what happened here and if it is likely I damaged anything internal to the transmission? Any conjecture would be appreciated.
Thanks, Matt
Old Jul 21, 2004 | 08:30 AM
Igor911's Avatar
My car does this sometimes also...and not just with 2nd...sometimes 3rd also.
Old Jul 21, 2004 | 08:55 AM
SR20DEN's Avatar
VQ Wizard
There is no problem. I can shift into any gear without the clutch once the vehicle is moving if I wish to do so. However it isn't healthy for the syncros and takes more time.
Old Jul 21, 2004 | 09:40 AM
Y2K2Driver's Avatar
Thanks for the replies. I was always under the impression that there was a clutch-shift interlock, but I guess not.
Old Jul 21, 2004 | 10:20 AM
Zero Deuce SE's Avatar
Thanks, Matt
I believe the lockout only works for reverse and possibly 1st gear. I know it does for reverse to keep you from shifting into reverse at highway speeds.
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
220k+ A32
Sep 11, 2015 02:18 AM
