clicking noise front wheels
Old Jul 27, 2004 | 07:15 AM
Ephraim's Avatar
i have a clicking noise from my front wheels, and it gets faster when i accelerate and slows down when i slow down.
i have seen this up here before, just want to know what is going on so i dont get ripped of when i get it fixed. thanks
Old Jul 27, 2004 | 07:20 AM
Larrio's Avatar
The Definitive AE Master
wheel bearing or axles/cv boot
Old Jul 27, 2004 | 11:20 AM
NYC TAR's Avatar
or you have some pebble stuck between the tire tread
most likely it axle ( don't replace cv boot cause it will make more noise) just replace the hole cv axle
Old Jul 27, 2004 | 02:24 PM
dgmaxse's Avatar
If it gets worst when you turn then it's probably a cv joint. Take a look under your car just inside each front wheel you should see a black rubber boot with ripples like an organ. CV Joints don't normally fail unless the boot is torn and dirt has gotten in and grease has gotten out. So look to see if either boot is torn.
Old Jul 27, 2004 | 02:27 PM
MaximaPolak's Avatar
I had a clicking noise....pulled over and i found a huge SCREW with a flat tip in the tire....that's what the clicking was......I bet that's not your problem though.
Old Jul 27, 2004 | 07:59 PM
Ephraim's Avatar
thanks guys, ill check it out this weekend
boomerbrian
Nov 8, 2015 05:10 PM
homeyclaus
Sep 3, 2015 06:15 PM
official_style
Aug 29, 2015 10:10 AM
twotonezed
Aug 16, 2015 11:41 AM
BassAddictJ
Aug 4, 2015 11:38 AM
