All you peeps with body kits...
Old Sep 29, 2004 | 12:40 AM
HNDA ETR's Avatar
Still Here... IM me for more..
How did you install/get them installed?
Double sided tape only?
Rivets only?
Double sided tape + rivets?
Anything NOT to do?
I just got my Stillen rear valence and MT Lip back from the body shop - just got painted - and I want to know how you all fastened your kits...
Anyone with a write up, pics, experiences, etc., please chime in...
thanks.
roy
Old Sep 29, 2004 | 05:00 AM
Qmax03
well 1 thing i KNOW NOT to do is put those screw thingies after a while the paint comes off of them i thing double sisded tape is the safest way .
Old Sep 29, 2004 | 06:32 AM
PoLo's Avatar
2-Wheelin it...
Rivets only?
Anything NOT to do?
thanks.
roy
the front lip should be fine with 2 screws at each end with double sided tape. believe me, once you screw it down, it will not move AT ALL
as far as the rear valence is concerned, i would have tried to have that molded onto the bumper, but alas, what's done is done...you can do the same. double sided tape and some screws at each end and it wont' move. if you notice, once you mount them, it's hard for them to come off as is. screws just secure it, but it's already a snug fit once you mount it.
Old Sep 29, 2004 | 07:29 AM
Hamy's Avatar
I agree with Polo that the front is cake. Just the two screws on each side + tape no problem. The back however is a biatch. I had the hardest time. Ended up taking back to the body shop 2 times to have it re-fitted.
Old Sep 29, 2004 | 07:44 AM
BP's Avatar
BP
the front lip is fairly easy to install since it pretty much secures itself. the screws at each end is all you really need. i added some 3m on the under side of the lip right where it meets the lower inlet just for good measure though.
the rear valence was less cooperative in my case. using just the double sided tape and two screws at each end resulted in sagging. in addition to the screws/3m i ended up using liquid cement (can't remember what type) where the valence meets the bumper on the back end (not the sides) to get it to stay without sagging. you can hold it place while it dries but having a extra set of hands would probably be better.
Old Sep 29, 2004 | 08:45 AM
Battle Max's Avatar
Are you keeping the oem rockers?????? i was thinking about doing the same thing.
Old Sep 29, 2004 | 11:08 AM
Cubanato's Avatar
Joo wanna play??......ok we go to war
my body put rivets and siad htey urethane glued everythings on......and now i need to replace my foglights cut they burtnout....and i dont know how to take the lip off without damaging anything...
-J
Old Sep 29, 2004 | 11:26 AM
Maxima-2's Avatar
Huh? I'm quite confused! when I installed my lip I only used the 2 "body" screws on each side. (I did this so I could remove it if I had to drive in winter as well as fog light replacement) THe sides I secured using 2 "body" scres in the front and rear and 3 rivits. THe back was orig. on w/ only the 2 "body" screws on each side which led to minor sagging in the middle which was quickly corrected with 3m tape! Good luck!
Old Sep 29, 2004 | 02:19 PM
WildmanAL's Avatar
My stillen front lip went on with just some double sided tape
Stillen rear I used double sides tape and then 2 screws in each wheel well to hold it on. It's on there very tight and istn't going anywhere.
Old Sep 29, 2004 | 08:51 PM
thomasd cook's Avatar
I used rivets and silicone to mount mine. I prefer rivets much better than screws because the heads are much less noticeable on the rivets. I also took some touch up paint and painted the rivets, so they are pretty invisible. I'll post pics this week of my kit I will finish putting the rear on since the body shop finally got my paint matched right.
Old Sep 29, 2004 | 09:20 PM
ICULookN's Avatar
When you say the "ends", do you mean where the front lip meets the wheel well?
Old Sep 29, 2004 | 09:40 PM
Ammi's Avatar
350 Detroit Muscle
double sided tape and hold them in place w/ rivets at the fender area
Old Sep 29, 2004 | 11:55 PM
HNDA ETR's Avatar
cool... thanks for all the replies, guys...
it sounds like my best bet is to use the 3M moulding tape (the double sided gray stuff) and screw/rivet the ends (where they end in the wheel wells)...
if it sags, then possibly some type of silicon or cement...
thanks again!
REDinLV
Aug 15, 2024 12:30 AM
mclasser
22
Nov 12, 2020 01:58 PM
msellas
Sep 23, 2015 09:16 PM
bumpypickle
Sep 20, 2015 08:22 AM
Jamie Bolus
Sep 13, 2015 05:56 PM
