Installed Berk.....Have Problem
Old Oct 19, 2004 | 05:51 PM
S00NR1's Avatar
OU > *
Okay, so I just got done installing my new Berk K&N intake, now my SES light won't go off, even after unplugging the battery for an hour. Any ideas?
EDIT: Would this have anything to do with the fact that I unplugged the sensor that was connected to the stock intake scoop that sits on the front of the engine compartment? I wasn't sure if that was supposed to be removed as well.
Old Oct 19, 2004 | 06:02 PM
nailz420's Avatar
Yes, it would, as a matter of fact. Its the intake temperature sensor, and no you are not suppose to disconnect or remove it. If you removed the front inlet scoup, you should still have the IAT sensor connected and ziptied some where next to the intake.
Old Oct 19, 2004 | 06:14 PM
S00NR1's Avatar
OU > *
OK, so take the scoop out, pull the temperature sensor out of it, plug the sensor back into the cable that plugged into the scoop housing, and then ziptie it somewhere near the intake?
Old Oct 19, 2004 | 06:43 PM
S00NR1's Avatar
OU > *
Alright, well I took the temp sensor out of the scoop and tied it to one of the lines just below the front of the filter, then plugged it back in to the cable. Will there be any problem with the sensor being exposed like it is?
Old Oct 20, 2004 | 04:55 AM
nailz420's Avatar
If its not banging againt something then probably not, but if it was what would you do? The best place for it is inside the front air inlet. Second best place is anywhere under the hood
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Tha'-Max
Aug 30, 2015 01:14 AM
kirkhilles
Aug 8, 2015 10:53 AM
