Programming remote
Old Oct 26, 2004 | 11:39 AM
NmexMAX's Avatar
dot dot dot ...
Programming remote
Newbie question...I know.
Anyway, iI tried the 6x in/out in the on position in the ignition and got the hazards to acknowledge, but after I pressed the lock button on the remote, nothing happened.
What is the correct button to press and/or the correct procedure for this?
I've rea the stickies and FAQ's, couldn't find anything.
Old Oct 26, 2004 | 12:16 PM
ddpack's Avatar
Try pressing both the lock and the unlock button at the same time
Old Oct 26, 2004 | 01:06 PM
Robdog69's Avatar
Once you get in your car shut the door and lock them. Then insert the key about 6 times until flashers flash. Turn the key over to the on position but not to start the veh. Push the unlock button and it should flash once. Press the lock button again and press the the other remote unlock button, after this you should be set. Been doing this for 2 + years (nissan tech)
Press both
lock & unlock 2 sec
beep---quiet
press unlock
once: driver door
twice: all doors
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
