Tranny fluid to be changed
Old Oct 30, 2004 | 06:22 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Planning on flushing my auto tranny next weekend. Can someone help me on this.. I have the write up and everything, now I will need the Auto tranny fluid. Which one and how many quarts.
Moderator please dont move this one, almosr no one looks at the Fluid section
THanks
http://www.myoilshop.com/AutoPrds.html
Old Oct 30, 2004 | 07:49 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
depends on what kind of exchange you are doing. are you doing a drain and refill or removing the line from the return line to flush it out? drain and refill typically netted me about 4.5 quarts on average and a little more when i dropped the pan. with the return method, it depends how many times it takes before the fluid coming out looks new. i think most said they used 10 quarts in 2 quart intervals. i use mobil 1 atf but whatever you get, just make sure its mercon/dexron III approved.
Old Oct 30, 2004 | 08:17 PM
Jime's Avatar
If you are using the writeup I did it tells you how much and what to use.
http://forums.maxima.org/showthread....15#post2806415
Old Oct 31, 2004 | 05:06 AM
Lontar1's Avatar
my car has 80k miles so I'm dropping the pan to clean the magnets and the crap...... I like to go with Mobil ATF from the best is the cheaper one......
thanks guys...
pktaske
May 6, 2016 07:49 AM
iamute
Sep 20, 2015 05:22 PM
Maxxx10
Sep 13, 2015 03:16 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
